Question about ASUS A7S8X-MX Motherboard
Installing SATA2 HDD
I heard you may have to do something with the jumpper pins on older motherboards, but I haven't found anything saying it needs to be done on this particular motherboard. My computer won't detect the hard drive, but I don't want to do anything unless I know it's necessary. Does anyone know if I need to do it?
    Brigadier General:
  • 6,966 Answers
Hi, No jumpers needed, you just have to enable it in your CMOS/BIOS settings. On start, press del to enter the Phoenix-Award CMOS/BIOS Setup utility: 1. In the Advanced window (Onboard Device Configuration), make sure the OnChip SATA is Enabled; 2. In the Main window arrow down to select First SATA Master, press Enter and select auto autodetect and values will be automatically filled; 3. Escape, Save and Exit. A few reminders: a. SATA will only work with Windows 2K SP4; XP SP1 above; 2003 Hope this be of help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 29, 2007
SOURCE:
I have un55f6350, sometimes the screen flickers, I have found a for a fix for older models, cutting a jumpper, but mine doesn't have the same power supply or jumpper
The t con board or the Lcd panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 26, 2016 | Televison & Video
Gigabyte g31m-es2c motherboard can't detect my sata hdd
dude make sure if the jumper pin is set properly
as i think your MObo is sata 1 support and all new generation Hdd are sata2 support so u have to set the jumper pin. the setting are different fro different Hdd so check the producers website.
Mar 16, 2010 | Intel Motherboard
Can I use a SATA2 HDD for P5GL MX?
just like usb1 and 2, the sata2 harddrive will simply clock down to match the speeds of its port. the connections for both types are identical so there are no possibilities of problems...other then the motherboard saying "nope i cant read that", which most likely wont happen.
ohyeah...ram does the same thing too.
but honestly, if you're using a mobo thats only sata1 and you've got the dough for a new 1tb harddrive, you should consider upgrading your motherboard first...much better money spent
Apr 26, 2009 | ASUS P5GL-MX Motherboard
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Reassembly problems.
WOW it goes beyond my understanding why anyone takes the bios or bios battery out it dosnt reset anything it just means youve lost your bios and need to re flash the bios again which without sitting infront of your computer i cant do. the first thing i would recomend is strip it all right down to basic so that the screen is connected the power supply and a keyboard if it dosent work then you got a buggerd motherboard
Apr 02, 2009 | ASUS M2N-E SLi Motherboard
P4VM800 SATA HDD Problem Plz Help me!!!
Check your user documentation for the hard drive to see if it has a user-accessible jumper that will switch it to 1.5Gb mode. I know that Seagate/Maxtor drives have a jumper they refer to as Force 150 and Western Digital calls their jumper OPT1 Enabled. If this option exists with this hard disk, it should solve your problem.
Mar 21, 2009 | Asrock P4VM800 Motherboard
ASUS A7S8X-MX Motherboard Logo
77 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
