Question about Amana NFW7300WW Washer
Water leaking soap dispenser - Amana NFW7300WW Washer
  • Amana Master
  • 744 Answers
If this is happening when on spin it could be a blocked pump.
Posted on Jul 22, 2013
Water leaking out of soap dispenser
I have had this happen. I have taken the dispenser tray out and cleaned the area where the water and the detergent will flow into the washer at. This area had gotten some gunk build up, once I cleaned it, it has not leaked since. Now I just routinely look at this and make sure that it is clean. Hope this helps you.
Mar 06, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Soap not dispensing
It's losing pressure due to the leak. need to fix the leak first.
Dec 23, 2013 | Techtronic FH50240 - Hoover MaxExtract 77...
Water leaking out of soap dispenser?
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 17, 2013 | Washing Machines
Kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
May 28, 2010 | Kenmore HE2 Plus Front Load Washer
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Amana NFW7300WW Washer Logo
27 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
