Question about Refrigerators
Samsung french door - door flap repair
The french door flap is broken. How do I remove it?
3 Suggested Answers
dblred
  • 68 Answers
SOURCE: Broken tab which holds ice chute door
unfortunatly, you cant. it is a unservicable part. if you ask me, it is one of the most rediculas design flaws I have ever seen. I run into this at many service calls, which means they break all the time. you have to buy a ney door to get the part with that plastic tab. im still baffled by this MAJOR engineering flaw
Posted on Aug 25, 2009
  • 401 Answers
SOURCE: on a samsung french door fridge is there a way to
I THINK THERE IS LITTLE SET-SCREWS IN THE HANDLE LIKE A ALLEN HEAD JUST LOOSEN THEM UP
Posted on Jan 13, 2010
How to repair Samsung rf265abbp/xaa door flap spring
I would need to see this to even have an idea as to whether it can be repaired.
Oct 29, 2016 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
Good day! The center flap (vertical hinged flap) no longer rotates back in when closing the left door. Result: the flap remains "out" when closing the door thus banging up against the right door.
Their is a factory issue on some models call the factory to see if your unit is a defective unit. Other wise the door flap has to be replaced. Not cheap..
Oct 30, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
How to replace door hinge
Hello there.
Well no specifics but all about the hinges are as I explain below.
All Samsung Support info about your fridge is here.
http://www.samsung.com/us/support/owners/product/RF268ABBP/XAA
So if you want Service or a dealer near to you, this is the place.
Page 9 of the user guide WITH installation manual shows how to get the hinge off.download from here
http://www.samsung.com/us/support/owners/product/RF268ABBP/XAA#
Sep 23, 2014 | Samsung RF268ABBP 25.5 Cu. Ft. French Door...
The seal or flap between the french doors doesn't retract
check it closely something has broke an the flap is not closing as u close the door
Jun 28, 2014 | Samsung RS2556 Side by Side Refrigerator
How to install spring on french door flapper/divider for Samsung RF266
On mine one end of the spring broke off in the hole on the door. It was on top of the hinge so it looked like a pivot pin. I found that this was the second hole for the spring. I pushed the end of the new spring up under the hinge and popped the broke piece of old spring out. Now I could see the 2 holes. You then need to put the spring into each hole. The hole on the flap also needs a white plastic sleeve if that is missing. that goes on the end of the spring and fits into the flap hole. Then the trick part is understanding how the spring works? If you put both ends of the spring in the holes and shut the flap, it now stays in position to close and be flipped open by the guide that swings it open to seal.
Good Luck.
Feb 03, 2014 | Samsung RF266ABRS Bottom Freezer...
SAMSUNG FRENCH DOOR ICE MAKER DOOR FLAP DOES NOT CLOSE model# 26XAEWP
You need to provide more detail, may be the ice itself is causing the problem?
If you have warranty, contact Service Center for free repair.
Or did you pull it too much? or something is coming in its way when closing removing everything and then try again.
Dec 09, 2013 | Samsung RF265AA Bottom Freezer French Door...
Ice flap stays open after dispensing ice letting cold air out-bad efficiency
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Mar 01, 2011 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
