What is the seer rating on the ck42-1c And what year was this unit made , S# 9908414296
22yooper
  • 828 Answers
SOURCE: Size and SEER rating
2 ton (24,000 BTU) 10 SEER
Posted on May 22, 2008
  • 182 Answers
SOURCE: I HAVE A GOODMAN FURNACE
seer is not a problem....18 would be fine.depending on the size of the blower,you may have limitations on tonnage of the ac.
Posted on Sep 10, 2008
SOURCE: what is the seer rating for this unit,and how old
for witch unit need name plate data information
Posted on May 03, 2009
hiltonjug
  • 612 Answers
SOURCE: Can you tell me the manufacture year and seer
Carrier puts this info or their data plates and have for a few years now. If it's not on this one, it's pretty old. If over 12 years, it will be around an 8 SEER or less. I you can supply a model number of the condenser I will be glad to look it up in my data base.
Posted on Oct 19, 2009
koolbreezes
  • 540 Answers
SOURCE: i have a goodman hvac model number phu024, what
The 24 tells us its a 2-ton system. The serial # tells the age, !
Posted on Dec 22, 2009
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
I had a power surge on my 15 year old HVAC residential Trane Unit. I can either have my insurance repair it or I can pay the difference to replace. I do have coverage to pay for Alabama state building...
13 seer minimum for new installs. I have seen ratings as high as 18 or more on
some units (410A systems)
I recently replaced my system with a 13 seer R22 system, since they are
more easily serviced and I am very familiar with them. Given the average lifespan of
a system before major service is around 10 years depending on model.
I have worked on Trane, Carrier, Intertherm and Goodman units and prefer the Goodman
units, as they seem to be much quieter running and are built in America.
Jul 15, 2011 | Heating & Cooling
I had Ruud heating and cooling installed five years ago. Last summer my electric bill doubled when I began running my air conditioner. It did not do that the first few years that we were in this house. ...
Hello In a way you are stuck with what is called a S.E.E.R. rating which is a statement of efficiency from the manufacturer.Ex: a 10seer is less electricity to run than a 14 seer.The model # would have told me the seer rating.A 4 ton `1 zone is a large unit but even a 10 seer 4 ton is never cost prohibitive to operate and Never doubles the electric bill in 5 days out of thirty.Is the home unoccupied all month and you use it on weekends?Did the neighbor run a strange wire to your property?There might be stray or lost voltage in rare cases if there is poor grounding issues.Has the unit been serviced? A low freon charge will cause a unit to run excessively long and not cool.Do you run the indoor blower all the time.Has there been any other major purchases made (at all) that you plug in?I would look at everything because there is some cause for DOUBLE bill amount not just the cooling bill.Good luck
Jun 18, 2011 | Ruud Heating & Cooling
How old is this unit? Will newer units be easier on electrical consumption?
Unfortunately, the model or serial number doesn't show in your question. I see this all the time, I guess it doesn't show all of your information sometimes. So for your first question, you will need the serial number if you don't have a manufacturing date on your data plate somewhere on the unit. In the serial number, it's usually the first 3-4 digits after the letters. Example C1085???. These digits in order will give you the month it was made and the year it was made, so in my example it would be made in October, 1985. It's really hard to tell without a serial number posted though. For your second question, any unit made before 1992 will have around a 10 seer rating or less and some there after. In the most recent few years, you won't get anything less than a 13 seer unit, which is about 30% savings in cost to run the unit and a lot less energy consumption. You can now get up in the 20's with seer ratings which save a ton of money but cost a lot too! Hope this helps and if you still can't figure out the year for your older unit, try posting the serial number in the question itself. Good luck!
Aug 19, 2010 | Heating & Cooling
NO PROBLEM YET, JUST HAD A GOODMAN AIR CONDITIONER INSTALLED MODEL CKL36-IL AND WAS TOLD IT HAD EXCELLENT EFFICIENCY TO FIND OUT THAT ITS A 10 SEER EFFICIENCY RATING WHICH I UNDERSTAND IS THE LEAST...
10 seer was the most efficient for the older generation units and in 1992, it was required that any unit has to have 10 seer or greater. The least efficient seer rating you will find on any new unit will be 13 seer which is a lot better than 10 seer and will save you almost 30% in energy cost. As of lately, they have made units available that are up to 20 seer or more, but they are pricey. I know you said you just had the unit installed, but from the model number, I'm assuming it is an older unit? If new, then it would have at least a 13 seer rating. Hope this answers your questions!
Aug 18, 2010 | Heating & Cooling
I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND OUT THE SEER RATING ON THIS MODEL.CAN ANYONE HELP?
Your going to need to know the age of the unit. If its less than 5 years old, its most likely a 13 SEER. If its anything more than 5 years old, its most likely a 10 SEER. If its anything over 10 years old, its most likely an 8 or 6 SEER.
Remember, that a unit will loose an average of 1-2 SEER for every full year of operation. This is just due to age, wear and tear, and usage.
So, if its a 10 SEER unit that is 7 years old, you could say that it is about as efficient as something in the 4-6 SEER range.
Jul 12, 2010 | Goodman CKL36AR36 Air Conditioner
Can you tell me the manufacture year and seer rating of a condensing unit with serial # 4397e02306?
Oct 19, 2009 | Carrier Heating & Cooling
I have a GE model No. BTN 748A100A1 (central air outside unit). Serial number 40564128. When was it made? What is its efficiency? It now handles #1950 sq. ft. Cab it handle 2950 sq ft when I remodel?
GE stopped making AC units probably 20 years ago. The same unit will not handle an additional 1000 sq. ft. I believe it is a four ton unit and about a 6 SEER rating which is way down on the efficency scale. You will need a 5 ton system to handle 2950 sq. ft. The average SEER rating now is 13.5.
Oct 07, 2009 | GE Heating & Cooling
Looking for rating
http://www99.epinions.com/specs/pr-Goodman_Split_System_CLJ36AR42_Air_Conditioner
Please rate my response, thank you.
Jun 04, 2009 | Goodman CLJ36AR42 Air Conditioner
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
229 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
