Question about Omron Hem-prt1-z Thermal Printer For Hem-705cp & 8 Rolls Of Paper
Printer History Can't get printer to print.
How to get print history of kyocera km-3050
you cannot print but you can view it only.
click on the panel the STATUS button
under printing you can view the print logs.
Good Luck!
Apr 13, 2016 | Kyocera Office Equipment & Supplies
Printer error
First confirm if the printer is recognized by your system,and check the printing history to see if there is a queue. If there is, delete them and restart your system. This time, make sure it\'s recognized, then resend your instruction to print.
Jun 12, 2013 | Office Equipment & Supplies
Xerox Phaser 3040 printer stopped after the first 3 pages
what message did you get?
Check the error history and job history for errorcodes.
May 28, 2013 | Xerox Phaser Office Equipment & Supplies
Zebra Printer zm400
You may try anyone of these option.
  • If you had this printer registered in the DNS, then its possible to obtain the IP assigned to this printer from the DNS server.
  • Earlier was the printer mapped to any print server on the network? if yes, you may obtain its IP from the print server.
  • Check the DNS cache from any PC that used to access this printer. Command to display DNS case is "ipconfig /displaydns"
Feb 08, 2012 | Office Equipment & Supplies
I can not print, and when I try to discover a new IP adress, there's no IP adress found. How can I be able to print again?
The way to find your ip is to printout the configuration page on your printer. You may need the network configuration report if it has one. Now you know the ip address you need to make sure the printer is set to DHCP which will mean it will automatically assign itself an ip address.
Go into the pc and find Add a printer. Tell it its a network printer and it will search for it and find it.
The rest is history!
Jul 14, 2011 | Office Equipment & Supplies
Can I pull up and print past history for faxes on my MFC-7420 ?
You can see your past history and can have its print if possible.
  • Insert your printer's USB cord into your computer's USB port.
  • Open your printer as a program by double clicking its icon that is located on your desktop (PC) or dashboard (Mac). This icon will pop up when your computer recognizes your printer via the USB cord.
  • Select the "Jobs" pull-down menu at the top of your screen while in your printer application.
  • Choose "Show Completed Jobs" from the "Jobs" pull-down menu
  • View every printer job completed or canceled.
Feb 18, 2011 | Brother MFC-7420 Laser Printer
Does the C6100 have fax history printout capablity?
Hi
Yes, Photosmart C6100 series does have the capability to print the fax history i.e. known as fax log, but its is only possible if you have not performed any resets recentlyt
How to print that?
Please follow the following steps to print it
1. Press the setup button on the printer
2. Go to the option that says 'Print Report'
3. Press Ok on print report
4. Scroll down using the arrow keys and go to fax log
5. Press Ok on fax log
6. This would print the history
All the best!!
Oct 29, 2010 | HP Photosmart C6100 All-In-One Printer
Stoopid Printer #*@!
Slow printing can be a result of excessive TMP files and a fragmented HDD. I would do a search for *.tmp;*.chk files, del all you find, goto IE, Tools, Internet Options, del cookies, files, and history, set history to 1 day, under settings, locateed next to Files, set diskspace to 10 MB, exit out, reboot, disable any screen saver you have, then do a full defragmentation of the hard drive. THis will take some time, best to set it to run overnight.
Once finished, do a fresh reboot, then try to print again.
Daniel (rydf)
Jan 18, 2008 | HP Deskjet 5440 InkJet Photo Printer
The printer won't print
Usb cable not secure
or delete and reinstall driver on pc
Dec 19, 2007 | Brother HL-2040 Laser Printer
Omron Hem-prt1-z Thermal Printer For Hem-705cp & 8 Rolls Of Paper Logo
27 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
