Question about Intel Computers & Internet
Power but no display
Intel motherboard power is on but no display on screen issues
  • Intel Master
  • 3,799 Answers
Change your RAM and then check the power supply is working correctly. A failed lead in the power supply can give the symptoms you describe.
Posted on Jul 22, 2013
2 Suggested Answers
romsky79
  • 822 Answers
SOURCE: no display in my intel d945gcnl but power is on
check first your RAM memory and your video card. if ok all. try another ATX power supply.
Posted on May 29, 2009
No display problem for intel D865GSA board
What are you formatting ? Have you changed the RAM. Does tour system work in its original configuration ? You do not say what the pattern of the beeps is. Before the display disappears, is there a message sent to the screen ?
From the manual
http://download.intel.com/support/motherboards/desktop/d865gsa/sb/d5600601us.pdf
Whenever a recoverable error occurs during POST, the BIOS displays an error message
describing the problem (see Table 53). The BIOS also issues a beep code (one long
tone followed by two short tones) during POST if the video configuration fails (a faulty
video card or no card installed) or if an external ROM module does not properly
checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors,
usually consisting of one long tone followed by a series of short tones. For more
information on the beep codes issued, check the documentation for that external
device.
There are several POST routines that issue a POST terminal error and shut down the
system if they fail. Before shutting down the system, the terminal-error handler issues
a beep code signifying the test point error, writes the error to I/O port 80h, attempts
to initialize the video and writes the error in the upper left corner of the screen (using
both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to
the operating system.
18.April.2014
18.April.2014
Apr 18, 2014 | Intel 865G Motherboard
Display probelm
After reading your issue,i am sure that there is problem with your motherboard.
as you cannot see anything on screen and you get power,that means your motherboard is faulty
so just get your motherboard replaced and it will be fine as before
Thanks
Jul 28, 2010 | Intel Desktop Board D845WN Motherboard
No display, i have already change my ram, processor, power supply but no result if i pull my ram replay ram beep from motherboard
no display is basically ram issue but condition that mother give u beep noise,
refix RAM proprely, chaque SMPS , PROCCESSOR,HARD DISK, Fixed togethar again ok resolve issue.
Mar 17, 2010 | Intel 845GEBV2 Motherboard
My cpu green led is glowing but monitor screen is black and keyboard led is continue glowing
There are No display in your system .Pls remove Power cable from CPU and again plug it and start your system.If display still not comes then pls remove RAM chip from slot in the Motherboard and re-install goods one and check it.if still display not come then issue with Motherboard .Its detter call vendor for repair the Motherboard.
Nov 19, 2009 | Intel Motherboard
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
Black screen even the power is ok!!
Your Intel D850MV motherboard uses an AGP video card. There is no onboard video (built into the motherboard). Before replacing the video card try swapping out your monitor with another. Check for display. When the system is powered on can you hear the internals running? If the swapped out monitor does not show display you'll have to replace the AGP video card. The Intel D850MV motherboard only supports AGP cards that run at 1.5volts only & can run at 2x or 4x speed. Intel shows the difference between compatible 1.5v AGP card connector & the 3.3v non compatible video card connector. Click on the Intel link to see this; http://www.intel.com/support/motherboards/desktop/sb/cs-009010.htm This next link shows a compatible AGP video card that will replace your old card; http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4116644&csid=ITD&body=MAIN#detailspecs Thanks for using fixya
Jun 04, 2009 | Intel D850MV Motherboard
No display in my intel d945gcnl but power is on
May 29, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
No display on screen and solid amber light on pcs' power button
Well hate to say it but that sort of problem results from a faulty motherboard or processor so if you say that you have changed the motherboard then you problem lies with you processor chip.
Jun 06, 2008 | Intel D865GBF Motherboard
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
Mother board dead
Hello how are you. Please give me ome detailed information the make and model of the computer. i will help you with this. Easy. This is what I do for a living.
Thank you hope to here from you
Feb 10, 2008 | Intel Motherboard
Computers & Internet Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
