Question about Briggs & Stratton Garden
Wont stay running and smoke coming out of the exhaust
    Sergeant:
  • 340 Answers
Rebecca sounds like too much oil on the plug. You may have stored it on an uneven surface. Remove the plug and clean it and then check the oil level is correct. It only needs to be above minimum on the dipstick.
Posted on Jul 23, 2013
Will only stay running on revs over 2000rpm if I take foot of peddle it cuts out also white smoke from exhaust
What is year--make--model?
Are you losing coolant? The white smoke may be coolant in the combustion cylinder, possibly caused by a head gasket problem. If head gasket problem, fix that first.
With idle issues, clean/check anything that has to do with idle air system. Any applicable trouble codes?
Nov 28, 2015 | Cars & Trucks
White smoke coming from tail pipe and wont stay ruanning
Failed Head Gasket
Major Repair
Coolant into exhaust-- no matter
what the fix is
Nov 27, 2014 | Mazda MPV Cars & Trucks
Smoke coming out exhaust
Sounds like the catalytic converter is bad. You need to have codes checked. See if there was some reason that would cause a bad cat.
Jul 13, 2013 | 2003 Mercury Sable
I have a 2004 for taurus that wont stay running
Has to be looked over & smoke tested for vacuum leaks,
old spark plugs,egr issues,exhaust & oxygen sensors & such
You can't guess,have no vehicle history & no way to know what these shop do, even when your there & ask & take your money
Have to hope you find an honest shop that can actually fix something
Feb 01, 2013 | 2004 Ford Taurus
Hit a rail hard. pink fluid leak, white smoke from hood and exhaust, loud whine noise, car wont start now
Pink fluid? Would that be transmission fluid? You have cooling lines running from the transmission to a separate reservoir in the radiator. Could that be the escaping fluid? Could the fluid have got on the exhaust and burned, and caused all the smoke? Or did the white smoke come out of the exhaust?
Check your fluids. Do you have pink coolant? Find and fix the leak, refill the lost fluid, and go from there. Good luck, drew.
Nov 30, 2012 | Cars & Trucks
Honda 8 horse engine , only 20 hours on it , starts if you put gas down the cab but leaks gas threw the ehaust and has white smoke when its running , wont stay running , then gas is coming out of the...
It sounds like your carburetor float is stuck open, which would explain the flooding, the white smoke, and the gas coming out of the exhaust. Sounds like you may have gotten a faulty carburetor. If you can, I would return it where you bought it and get a replacement. Else, you will need to have the carburetor rebuilt, or have the valves checked out.
Jul 02, 2011 | Honda Pressure Washer PSI 3000
Black exhaust smoke comes out of tail pipe, now it wont run how do I fix this and where do i start
Black smoke is a sign of too much fuel. First make sure the air filter is clean. Now note if the check engine light works, and if it stays on, get the codes read to get an idea of what error the computer has found. (A bad coolant sensor for the computer can make the computer think that it's well below freezing and increase fuel) Try these as a start.
Sep 26, 2009 | 2000 Ford Focus
Injector problem 4 litre eng.
hook up to computer (snapon,otc,ect.)need more data to diagonois properly don,t think needed injectors at all head gaskets, map sensor commen on this vech.6184512886 bigjim.
Nov 30, 2008 | 1995 Oldsmobile Aurora
Garden Logo
46 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
