Question about Cameras
Canon 60D I am using a canon 60d. no matter what settings in aperture and shutter speed, i have to press twice to take a picture (i always do halfway pressing for auto focus). what can i do to fix this - i mean to to take a photo by pressing only once. pls help. thank you.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 54 Answers
If the problem is exposure delay (2 seconds delay timer) check drive mode setting, set to single shot.
Posted on Jul 23, 2013
The flash on my canon eos 60d not working
Possibly the spring that raises it is broken, or there is foreign matter in the hinge. Can it be raised manually ?
Oct 03, 2016 | Canon EOS 60D Digital Camera
How to get flash on canon 60D to pop up
Go into the menu and ensure it is 'enabled' to fire automatically. Or press the lightning arrow button on the side or in a darkish room set the aperture to something like f16 and press the shutter button.
Jun 25, 2016 | Canon EOS 60D Digital Camera
Canon 60d internal flash not popping up
Check the metal tabs inside the notable rails as they need to touch the upper part of the rails to allow built in flash to work
Use a micro screwdriver to push the tabs up to the rail
GENTLY as that was what was wrong with my canon digital body
Jun 21, 2015 | Canon EOS 60D Digital Camera with 18135mm...
60d flash pop up
Mode dial is set to an auto mode or the setting is set for flash photography. Change that and the built-in flash unit won't pop-up every time you press the shutter button.
Feb 28, 2015 | Canon EOS 60D Digital Camera
Hi there. i owned a Canon EOS 60D model camera. The problem is, its AF option is not working except Auto n 'C' modes. While i am trying to use it in M mode with AF, its not working but in auto mode an
Are you sure you did not put the AF/ MF switch in the wrong position? Although I don't think it would focus in Auto mode. In all other modes, are you sure you selected a (or more) focus point(s) in the centre of the frame?
When the selected focus point is on the side of the frame it won't focus on the parts you want it to focus. Then while pointing to the point you want the camera to focus, please press the shutter release button half and what till it focusses. Then press it the whole way down. Be aware the camera needs enough light to focus and certainly can't focus with a lens wit a min aperture of 6 or a larger number. On your 18-135 you can shoot at f16 because it will first focus on wide open and only close the aperture after you pressed the button.
Jan 27, 2015 | Canon EOS 60D Digital Camera
Why is sports mode not working?
If you are trying to take photos in very dim light the sports mode may not work. Sports mode selects a fast shutter speed to freeze the action and in very dim light with some lenses the aperture may not open wide enough to allow enough light to hit the sensor.
Aug 18, 2014 | Canon EOS 60D Digital Camera
  • is your settings set to manual ? if you are set to manual mode and the flash does not pop out try pressing the flash button located near the EOS 60d label
  • if the flash won't pop out after pressing the button try to follow the steps on this you tube link
How to fix the This menu cannot be displayed External flash is attached...
Aug 17, 2014 | Canon EOS 60D Digital Camera
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Canon 550 ex speedlight - flashes okay. Won't sink with 60d (tried different cameras at dealer - same problem) Camera is okay .
Bruce,
Try these steps:
1. Set camera to manual2. Set shutter to 1/60
3. Set aperture to F5.6
4. ASA/ISO 200
5. 550EX on hotshoe
6. Do not set on slave or master
7. Turn on flash
Display must shows, ETTL.
If that doesn't work, you have to use the flash on manual.
Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me.
But that can be costly when you can get the 580EX II for less than $425.00 USD.
atdlee@netzero.com
Jan 01, 2013 | Canon Speedlite 550EX TTL Flash
Metering in manual or Aperture Priority
I have found with this camera that when you set the aperture and shutter speed in manual it will display recommended settings and not the settings you had just set. But when the picture is taken and you display the settings in software that the camera used, it actually uses the settings you set and not the ones displayed on the camera. I think the settings displayed are recommended settings. Very strange! Also the camera changes settings on zooming.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
