Question about Dirt Devil SE2800 Spot Scrubber Handheld Wet/Dry Vacuum
Solution dispenser seems clogged,how do i unclog it
Hoover wind tunnel platinum not sucking. How do I unclog it
You have to take the bottom plate off and remove the roller, from there you should be able to see or find the clog ! Be careful putting it all back together, the screws can strip the holes very easily.
Feb 20, 2015 | Hoover Vacuums
Hoover h3000 replace assembly
Borax is alkaline. Try putting a few ounces of straight vinegar into the bottle, as it is quite acidic. It might foam a bit, but it should eventually "burn through" the Borax clog if you leave it a day or two.
(Picture that!)
Jul 27, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
No suction
the hose can clog up insid where you cant see it my husband takes it off and runs water thru it to flush stuff out lets it dry then reconnects it
Sep 18, 2012 | Dirt Devil Featherlite Bagless Vacuum...
My hoover floormate h3060 has not been used for some time, when I went to use it, it would not dispense the cleaner..The last time I used it, I used a mixture of amonia and borax. I think the hose is...
You most likely have either a clogged screen at the bottom of the fill tank or the jets that spray fluid are clogged. You can unscrew them and power a paper clip through them. If the hoses are by chance clogged which doesn't happen often, Pull one off at a time and blow real hard to unclog, then put it back on, then move to next hose.
Do NOT take all of them apart at the same time or they can get mixed up and it's a pain to figure out how it all went back together.
Feb 07, 2010 | Hoover H3060 FloorMate SpinScrub 800...
I have kenmore progressive and it is clogs is there a way to unclog it
The easiest way we unclog this machine is to take another canister vacuum and use its' hose to put on the hose of your machine then switch it on and **** the clog out of your machine. Works great.
Dec 01, 2009 | Kenmore Vacuums
Troubleshooting for Bissell proheat
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Jun 14, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Shampooer dispensing
I occasionally run some water and vinegar (equal parts) through the machine, just as I do for clogged holes in my steam iron. So far it has been doing the job.
Nov 03, 2007 | Dirt Devil CE6000 Featherlite Wet/Dry...
Dirt Devil SE2800 Spot Scrubber Handheld Wet/Dry Vacuum Logo
51 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
