Hiyundai i10 eps
Hi My Hyundai i10 irde era, experiencing power steering problem. The eps indicator is ON and steering wheel is very tight. I took to nearest Hyundai service centre and i am told that the entire eps module has to be replaced and it will cost around Rs 22000. Does this actually cost this much ?, Can the entire EPS system change part by part ie motor/electronic module etc ?, If yes how do i make sure that they are not cheating by replacing certain components charge me 22k ? Thanks in advance. Jaleel
  • Sachin Raswant
    Sachin Raswant Feb 04, 2015
    no not that much amount u can get a EPS module as cheap as Rs.4000.
  • Sachin Raswant
    in most of the cases the EPS module is the culprit and a very little chance for any other faulty parts
Intel motherboard power is on but no display on screen issues
ram is ok , smps is ok
Posted on Jul 22, 2013
Eps light indicating. does not go off when engine running
Did you change the battery? IF so that can cause this. The EPS is electric power steering. There is a motor that assists the steering system and if you remove the battery, it can have problems. If you hit something and the alignment went out or if you had it aligned by someone that does not know about these, it can cause problems.
Mar 18, 2014 | 2006 Hyundai Accent
Hiyundai i10 power streering problem
you can ask for a part number & try to buy it from another source.
you can ask that they return the old item to you after replacement, the part numbers on the invoice & on the old unit should match.
May 19, 2017 | Hyundai i10 Cars & Trucks
Esp light on 2001 aclass
Hi there lose of power steering and the eps light coming on could be the power steering pump is broken or near stuffed so will require a new pump. The other reason is that your power steering oil level is to low and needs toping up. Also check that the drive belts driving the power steering pump are tight and not slipping.
Hope this helps.
Mar 31, 2013 | Cars & Trucks
Hyundai i10 Steering not rotating. It seems to be locked. Pls help. The wheels were tilted to other end so, I tried to straighten by turning the steering even before starting the engine. But when I start...
Faulty Steering?
It was not until later in the day as I check the Internet for "hyundai i10" "steering locking" that I started to worry once again. I found reviews and comments mentioning that the i10 had problems with its power steering system which sometimes caused locking while the car was in motion! This post about hyundai i10 steering locking is what really caused me to get worried again. I still puzzled a bit and not sure if that was the same case as mine as in my case the locking took place while the car was at a stand still and turned off. I'll try to follow up on this carefully to see where it goes. Perhaps I should mention this issue to the agency as they service my car after the first 1000 miles (or first month of driving it).
Update: After describing the problem on an Arabic cars forum I learned that nothing was wrong with my i10. The steering locking was normal since I tried to move the steering too much while the car was turned off. As for the key not turning in with ease, the reason was that I must have moved the steering slightly after inserting the key and before turning the key. This is the method used for turning the key whenever the steering has locked. Man, I just love those forums and i LOVE the Internet.
Oct 24, 2012 | 2010 Hyundai i10 1.2
Eps in hyundai accent 2007
EPS is Electronic Power Steering.
When the light comes on, it is a warning that the Electronic Power Steering system is having a problem.
The increased force you have to use, is because the EPS is not assisting you as much as it was before, if at all.
Here is a link to a video explaining the basic operation of the electronics at youtube.
Jul 28, 2012 | 2007 Hyundai Accent GS Hatchback
Why does the car drag when changing gears? the various lights on the dashboard are blinking and it shows EPS
EPS indicates Electronic power steering warning light.---------The power steering needs to be inspected.The power steering pump, the power steering fluid, the power steering hose ,power steering belt and pulley. Get your car scanned by the dealer or at local car garage.That will be much helpful.As you will receive codes, as per codes you can replace the part or get the part checked.A fault in the wiring loop causes it to short on the steering column.This problem is very much noticed in Hyundai cars.-------
This will solve the problem or point you towards the cause of problem. Thank you for using fixya.
Jul 01, 2011 | Hyundai Elantra Cars & Trucks
EPS light is turn on how can i turn off its?
EPS
EPS: Electronic Power Steering - enables the amount of assistance with steering to be varied depending on speed and how much you turn the wheel. This means it can give lots of boost when parking the car whilst still giving you a good feel for the road at speed.
Jun 20, 2011 | 2006 Hyundai Accent
My car I10 magna 1.1 irde, when engine starts battery, oil etc warning lights shut off immediately but malfaction light & EPS light shut off one after one. Is this any problem pls clarify.
Ok, with the battery, oil etc lights are governed by simple circuits, and therfore, as soon as they receive power, and earth, they turn off right away.
With the other lights, the malfunction and EPS lights, these go through a self-test function where they check a number of sensors, not just one, and they do this very quickly......the malfunction light checks out 20-35 different sensors, and in less than 1-2 seconds, thats fast.........
However, if they STAY on, then this is where it detects a problem and you should come back and see us again.
If you liked this response, please vote !!!!!!
Jul 14, 2010 | 2007 Hyundai Accent GS Hatchback
Hi i have Hyundai Elantra 2007 its EPS light
Hello... This light indicates that you might have a problem with your Electronic Power Steering (EPS)...
Have a shop check it out...
Mar 26, 2010 | 2007 Hyundai Elantra Limited Sedan
Computers & Internet Logo
656 people viewed this question
David Payne
David Payne
