Question about Dell Inspiron Computers & Internet
Plug & play driver
How to update driver for plug and play devices?
    New Friend:
The pug and play devices automatically update its driver when attached to a system. Even if it doesn't then you can download the latest driver from the net and install it in your system.
Posted on Jul 22, 2013
I have downloaded the driver but I cannot update it. I had to reinstall windows xp and the everything has gone back to original settings.
Right click my computer ,go to properties ,then click hardware tab ,then go to device manager when device manager opens ,on the right pane u will find monitor listed on clicking the + mark you will find Plug & play monitor listed, right click on the monitor ,you will get a option update driver ,then locate the driver files,&that's it.
Apr 20, 2013 | Dell E173FP 17" LCD Monitor
I Couldn't find out it's driver
3 com NIC card is universal plug & play device.
Please restart the computer once you insert it.
If still persists, update the driver from
"C:\Windows\system32"
All the best!!
Jan 30, 2011 | 3Com OfficeConnect 3CSOHO100B-TX Network...
Am getting error no 41 i.e my laptop is not recognozing my dvd
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Nov 25, 2010 | Philips (JR4DVDRWK/00) DVD+RW Burner
My Princeton VL1919 is working but the picture is blurry. Is there a driver I need to download? Or another fix? Thank you!
Did "Guest" (06/25/10) ever get a solution? I'm having the same problem. The graphics card is:
RAGE 128 PRO UltraGL AGP
Driver (per Device Mgr.) is "Plug & Play"
Should I update the graphics card or try to find a VL1919-compatible driver? From where?
Jun 24, 2010 | Computers & Internet
My CDR/DVD doesn't work. I have a yellow ! over the hardware device. Using the Windows Add Hardware Wizard it shows that Windows has successfully loaded the device driver for the hardware but can not...
Hello, if looked this error code from Microsoft self, just have a lokk and see if you have tried all of these.
This problem occurs if you install a driver for a non-Plug and Play device, but Windows cannot find the device. Here are some things that you can try to resolve this problem.
If the Troubleshooting Wizard does not resolve the problem, do one of the following:
  • If the device was removed, uninstall the driver, connect the device, and then click Scan for hardware changes to reinstall the driver.
  • If the hardware was not removed, the driver files might be obsolete. In this case, update the driver from Device Manager. In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
  • If the device is a non-Plug and Play device, you may have to install a newer version of the driver. To install non-Plug and Play devices, use the Add Hardware wizard. Click Start, and then click Run. In the Open box, type hdwwiz.cpl.
If that doesn't work, i tried this program once at a frined of mine with the same problem as you have now and it worked perfectly.
Link below:
http://microsoft.pcerror.info/errorcode/code%2041.html?gclid=CMKowK-575wCFdYB4wodDjz1kg
Really hope hat this can help you.
Sep 13, 2009 | Dell OptiPlex GX520 PC Desktop
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Driver/Firmware Problen on a Lite on CDRW
Here ya go straight off the Microsoft Knowledge Base. Geek Squad too lazy to research:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Recommended resolution
4 diamonds pls
Mar 01, 2009 | Gateway 510 X PC Desktop
HELP ME
Code 41Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
Let me know how this works.
-Tha Mp3 Doctor
Jun 17, 2008 | Insignia Pilot MP3 Player
DVD DRIVE NOT BEING RECONISED
This is a solution for error code 41 but it may assist you with your problem.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Good luck.
Apr 07, 2008 | Computers & Internet
Redgroove digital mp3 player voice recorder
PC does not recognize player - sure you used the right driver?
Code 41Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)Recommended resolution
Feb 12, 2008 | iRiver iFP-895 MP3 Player
Computers & Internet Logo
Alun Cox
