Question about Ricoh SP 3410DN Laser Printer
3410 light codes print
Ricoh 3410dn printer paper jam in unintentional
SOURCE: Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Posted on Feb 07, 2008
Cogz
  • 1326 Answers
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Posted on Jan 25, 2009
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
  • 22 Answers
SOURCE: Ricoh CL2000 SC486
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
Posted on May 30, 2009
  • 46 Answers
SOURCE: paper misfeed in ricoh printer
1.Remove tray and clean the feed roller with cloth and 'fantastic" or windex. Make sure you rub dry after cleaning. All of this should be done with a ragg not a towel. You don't want lint on your roller.
2.make sure end fence (back guide in the tray) in in contact with paper.
Posted on Aug 28, 2009
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Why duplex paper jam in ricoh 3045
Clean the roller with water or Isopropyle Alcohol. It works 100%.
Aug 31, 2014 | RICOH - PRINTERS Ricoh Aficio Sp 3410dn -...
Ricoh c2050 continuous paper jams
Problem with the hot section, service call needed. -Carl
Mar 25, 2014 | Ricoh Office Equipment & Supplies
When switch on the printer indicates red alert Printer Model sp3410dn
You need to download SOM smart organizing monitor from ricoh website. you will see the error or error code.
Oct 28, 2013 | Ricoh SP 3410DN Laser Printer
All indication are glow
You need to download SOM smart organizing monitor from ricoh website. You will see in the SOM what is wrong with it or an error code.
Sep 30, 2013 | Ricoh SP 3410DN Laser Printer
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Got problem with aficio250
Another thing that can happen to cause a jam when you are printing on there is to make sure that the paper size if correct and matches the trays you are printing to. That condition will happen if the printer tries to print a legal size page and you only have letter paper installed in the trays.
Check your settings in the printer control panel to make sure that the trays match and are correct.
Make sure that the green paper setting knobs match the correct tray size as well.
Jun 19, 2008 | Ricoh Aficio 250 Copier
Ricoh SP 3410DN Laser Printer Logo
37 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
