Ecobubble Hi, i Have recently purchased an 8kg ecobubble, its great apart from now and then it squeaks, like the rubber seal is rubbing against something. it tends to do it during washing and sometimes when its spinning, do i need to get it looked at?? thanks. Jayne
SOURCE: removing rubber door ring from Zanussi Aquacycle 800
getting it off is not the problem (just find the clip at the bottom of the seal and let it off and you can pull the seal out....getting it or a new one back on is the real problem...that I am looking for help on!
Posted on Dec 12, 2007
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
  • 39 Answers
SOURCE: very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Posted on Sep 16, 2008
  • 40 Answers
SOURCE: Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Posted on Mar 10, 2009
  • 41 Answers
SOURCE: HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Posted on Sep 03, 2009
How do I fix/diagnose my washing machine, The belt keeps slipping off?
if the drive belt is v section the reason for coming off will be pulley misalignment
easy to check with a straight edge
check that the belt fits in the pulley so that the top of the belt is level with the pulley edge
Jul 21, 2016 | Samsung Ecobubble WF80F7E6U6X Silver 600...
Can a shock mounting make a squeak noise when going through a dip or turning the steering wheel. shocks already tested.
There are a lot of suspension points that can develop a squeak. Look at there: Front strut tower mounts, sway bar rubber mounts(if equipped). If you recently got new tires that may be a little larger than the originals, the tire may hit suspension parts when turning. They can rub against the inner fender well plastic parts as well. Best thing to do first is get a chassis lube. If that fails to resolve the problem, then look deeper into the problem by a good mechanic.
Jul 02, 2014 | 1997 Nissan Sentra
How to inflate pneumatic tires?
You will probably find that they are infil tyres which are classed as solid, so they can not be inflated, your problem will lie elsewhere,ie :- something rubbing against the tyres.
Apr 03, 2014 | Pride Health & Beauty
Sebring window
Look into window guide clips. These push the glass against the rubber
Oct 28, 2013 | Cars & Trucks
Turning left or right the steering wheel on my 2003 Camry LE sedan squeaks (or rubs). Looking for the perfect mechanid
In most cases, the squeaking is caused by the steering column where it goes through the firewall, there is a rubber dust seal where the shaft goes through. Try to lubricate the shaft where it makes contact by pushing the rubber boot back a little then applying a clear silicon grease or silicon spray to the area of contact. If you do need to replace your steering shaft this site looks like it has cheap prices, free shipping and great reviews http://www.buyautoparts.com/steering-shaft.html
Aug 04, 2013 | Vehicle Parts & Accessories
Why is my coleman mach squeaking
Our AC did this and needed bearings replaced. Cost $10 dollars to fix it. Husband did the work. Took him less than an hour to replace the bearings.
Jul 10, 2012 | Coleman Mach III Air Conditioner
Paper Jamming
See if canon sell a Roller PM kit and replace the rollers.  you could try cleaning them with a lint free cloth and some fresh water.
May 28, 2009 | Canon PC-921 Black and White Copier
Washing Machines Logo
236 people viewed this question
Top Washing Machines Experts
