Hinari refresh air PAC12400HC
Keep getting E2 error meesage yet water has been emptied!
4 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: Hi need to find a
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Posted on Dec 21, 2010
SOURCE: hi i need a opperators manual for a hinari refresh
Hi
I have one of these units.
To dehumidify, you remove the exhaust pipe, check the water collector is empty and then set the mode to DRY.
Keep doors & windoiws closed.
You don't need to set temterature, fan speed etc as that is for the cooling & fan only mode.
if it runs for a while and then stops, or does not run it may mean that there is frost on the evaourator coil benind the filter on the left side of the machine. alow it to defrost & the unit should run.
also check it is not in timer mode - by switching off, unplugging and plugging back in.
Hinari support is : 0870 873 0077
Posted on Dec 29, 2010
hvac1960
  • 2133 Answers
SOURCE: Fedders air conditioning error code E2
Indoor coil temp defective. Replace it.
Posted on Jan 01, 2011
Hi need to find a operating manual for my Hinari refresh air model PAC9100C/FC as i,ve lost mine.
Dec 20, 2010 | Heating & Cooling
Opperating an hinari refresh air pac9100c/fc air conditioning unit
Hi I have the Henari Refesh Air 3-in-1 and am having problems get the Dehumidifier only to work. I've done as above. There is a little pipe inside next to the water collector. This is inside. when i put the water collector tray in the machine switches off. I have switched it off and on and set it to dry but nothing is happening. If i take the water collector out then it switches on and u must unstop the pipe and ly it in a bucket. the machine then switches on and runs but the "water full" light then comes on and after running it for about half hour nothing seems to happen? Can you please help. I have a serious humid problem in my house.
Nov 25, 2010 | Heating & Cooling
Hi i need a opperators manual for a hinari refresh air pac9100c/fc can you help.or tell me how the dehumidifier opperates. many thanks trevor
Hi
Nov 19, 2010 | Heating & Cooling
What to do with an E2 error message.
that means the water condensate tank is full, you must unplug the unit, take it outside, unscrew the condensate tank plug cap, pull out the black rubber plug and let the water flow out until empty. then replace the plug, screw cap back on, roll inside, plug in and resume cooling. good luck! :)
Jul 19, 2010 | NewAir ACP-1000E Portable Air Conditioner
I have an E:13 error light and I've tried Refresh and running it through empty many times. Please help
this is a water leak in the tub or the air bell.
the air bell is part of the unit that is connected to the pressure switch that stops filling when it gets to the righ amount of water. the pressure switch is usually located to right side of the washer under the lid you can trace a small black rubber hose down to the air bell and look for a crack and or a hole in the rubber hose.
Jan 31, 2010 | Washing Machines
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
May 24, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
I HAVE A HINARI REFRESH AIR 3 IN 1 AIR CON DEHUMIDIFIER
May be a bit late for this one but if you go to www.hinari.co.uk
there is a help line with these phone numbers
CUSTOMER SERVICE: 0161 621 6900
SPARES LINE: 0161 621 6855
Anne
Dec 21, 2008 | Dehumidifiers
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
