Ay atb083 i need display for GPS AYTOBE ATB 083 , PLEASE
I have aytobe atb083 now coming error i think i need update so please help me
Go to manufacturer's website. Or why didn't you search "aytobe sat nav updates"???
Try. http://digital-forums.com/
Aug 08, 2015 | GPS
Sagisag ng kromatiko
This doesn't seem to translate very well, but it seems like you might be wanting to switch your display to black and white or the reverse of that. This is typically done by adjusting the saturation to zero, and it will likely need to be done via adjustment of manufacturers display driver vs the Microsoft driver.
Ito ay hindi tila napaka-translate na rin, ngunit ito ay tila tulad ng sa iyo ay maaaring kinakapos upang ilipat ang iyong display sa itim at puti o ang reverse ng na. Ito ay karaniwang ginagawa sa pamamagitan ng pagsasaayos ang saturation sa zero, at ito ay malamang na kailangang ma-tapos na pag-aayos ng mga tagagawa display driver kumpara sa mga driver ng Microsoft.
Jun 09, 2013 | Computers & Internet
Tv codes for xkd sl 083 remote control
try these 001,014,018,022,029,032,034,038,052,055,089,118,138,151,191,224,233,234,407,412,430 ive got the same thing one of these codes are it
Jun 28, 2012 | Televison & Video
When iturn my wheels to the left my atb light comes on, when i straighten out the wheel the light goes out , the light does not come on when i turn to the right, whats wrong?
One side of your ATB is damaged and needs to be repaired/replaced. Below will explain what this is and what it does.
The QUAIFE ATB differential is designed to prevent the complete loss of drive that occurs with a conventional differential when one wheel slips. Whilst requiring some torque in the slipping wheel, the QUAIFE unit is progressive in action but never locks - controlled power is transmitted to all the driving wheels. Ideally suited to high powered front wheel drive systems, QUAIFE ATB differentials are also used in rear and four wheel drive vehicles where optimum traction is required. Installation is identical to the normal differential with bearing pre-loads and pinion mesh being restored to the original manufacturers' settings. Servicing of the unit is simple as all gear pinions are free fitting and normal final drive lubrication oils are retained.
As engine power outputs increase ever further, the ability to utilize this extra performance becomes more important. Wheel spin may look spectacular, but such losses of traction waste time either from a standing start or exiting a bend, whether driving on the road, circuit, rally stage or drag strip. Fortunately, QUAIFE's patented Automatic Torque Biasing (ATB) Helical *** differentialis an effective, well-proven, low-cost solution.
Aug 26, 2011 | GPS
At 100% the garmin nuvi 255w cannot be heard...ay thoughts?
Yes, most like the speaker has died. Please see this link for troubleshooting & repair info.
http://www.sharc.net/gps_audio_repair.htm
- Jim
Mar 09, 2010 | Garmin nuvi 255W GPS Receiver
Hou ay can transfer fils of my pda
you can transfer files to your pda by connecting it to the USB PC port with the data cable (use Microsoft ActiveSync to transfer files, it works for PDA, GPS etc).
you can also use a memory stick to transfer files to your pda if your pda has such a thing (you just need a pc card reader, usb-pluggable)
Nov 27, 2009 | Computers & Internet
Where can i get an updated map for my mio-tech p550
you will need to go to the web site o the gps maker and see if ay new maps have been released, there is a $100 charge for this map upgrade is a new map program has been released..
Oct 14, 2009 | GPS
Ay to be sat nav
try charging battery hooked up to the computer
there also is a lock on the start button
slide halve way instead of all the way over
May 30, 2009 | Tomtom One XL GPS Receiver
Ay to be sat nav
you need to install the update from this link, I've just done it and my Aytobe sat nav is working much better and it's holding a charge too http://www.aytobe.com/html/updates.html
HTH
Mar 20, 2009 | Tomtom One XL GPS Receiver
I turn my GPS on and it kept showing GPS 1% firmware. Can you please tell me how to get rid of this problem
Please go to the Garmin website at www.garmin.com and download their webupdater on to your PC. Connect your Nuvi to the PC with a USB cable and run the webupdater. It will check to see if you need ay firmware upgrades and also look for a selection called GPS chipset. You want to upgrade your Nuvi with the GPS chipset. Your GPS receiver has corrupted data and needs to be reflashed.
- Jim
Nov 21, 2008 | Garmin GPS
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
