I using kx-dt343 White 24 Button. Main physical extension (extension no. is 0543) and i set two extension (204, 205)on 0543 extension using their flexible buttons and when i dialed 204 or 205 no ringing voice on 0543 extension.....just blinking light but when i dialed main physical extension (0543) ringing voice is work. Pls help on flexible buttons ringing voice.... My PBX is Panasonic tde200
SOURCE: Panasonic cordless phone
HI. I had to unplug the phone from my wall outlet and then plug it back in again. It worked! I had to reprogram everything again though. Thanks.
SOURCE: How do you take apart
Use Philips screw driver to remove the screws.There will be 5 screws.Round sticker covers the screws.If you remove the sticker the warranty will be void.So if it is old one you can go with it.
Normal procedure while opening check for the gaps and open.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: I have a model #
When I encounter these types of issues, I usually 'reset' the system
back to the 'default' settings to restore the ringers. You can do the
same by following the directions below:
1) Unplug the AC adapter from the main base unit AND the wall.
2) Remove the battery for each handset in the system.
3) WAIT about 15-20 minutes.
4) Put the batteries back in each handset in the system.
5) Plug the AC adapter back into the main base unit and then the wall.
6) Wait about 30-60 seconds for the system to initialize again.
7) TEST each handset in the system.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: How can I change the
The amount of rings before a call goes to voicemail is setup on the network itself and not the phone. Some mobile providers won't let you modify it and others will depending on your region. You would have to call your mobile provider for the availability of the option and the procedures. Sometimes you dial a number to change it other times it can only be changed manually by the provider.
Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
very easy call for help or email
