Question about Refrigerators
Defy F350 Upright double door freezer wiring manual
The fan does not switch off when the top door is opened.Is this due to a faulty microswitch or thermostat, and if so , how does one access it?
Master_Tech
  • 770 Answers
SOURCE: How do I test the defrost thermostat?
the fan is ctrl by the Jazz board the thermdisc is for defrost post your email and I will send you the manual on test process and test point as well as the defrost
Posted on Feb 12, 2008
buddymcl777
  • 67 Answers
SOURCE: freezer door not sealing
replace the seals and / or have the hinge adjusted
Posted on May 01, 2009
SOURCE: I need a wiring diagram for a Defy upright freezer Model F 350 wiring connections to PC board thermostat
Defy F350 uprigt freezer ices on evap coil righthand red led are displayed. Can the heater or ice sensor be faulty.Thanks Marius
Posted on Jun 28, 2009
aasc
  • 1606 Answers
SOURCE: Refrigerator does not cool.
Ok , I'll help you .
Pull the refrig out from the wall , and unplug . Remove the 8 " X 10 " panel on the back of the refrig . Inside this panel , is the main control board .
Remove the blue plug with 3 larger wires going to it . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . Get a short piece of insulated wire , and remove about 1/4 inch of insulation , from both ends . Insert 1 end of the wire , into the slot of wire2 , and the other end , into wire3 .
Plug the refrig back in .
After about 2 min , look inside the freezer , behind the bottom crisper , and look for a red glow . This glow , is the defrost heater .
If no glow , this is an indication of a shorted defrost heater , or bad defrost thermostat , both of which are located behind the rear freezer panel . Unplug the refrig , and reinstall the blue connector , and the 8 x 10 panel .
The pt # for the heater is WR51X10101 , and the part number for the defrost bimetal is WR50X10068 . Both should be replaced . The heater is at the bottom of the coils , held on by 2 screws , and the thermostat , is clipped on the top right of the coils , with a blue and pink wire going to it .
If you do see a red glow , reasemble as above , and remove the rear inside freezer panel . At the top of the coils , on the left , you will see 2 white wires attached to a 1 " piece , which is clipped to the coils . This piece is the # 4 thermistor ( evaporator thermistor ) . Pt # WR55X10025 . Also replace the # 5 thermistor , ( freezer thermistor ) which is at the bottom of the panel , slid into a holder , also with 2 white wires going to it . Both thermistors , sent readings of temp , by coldness resistance , to the main control board , which then decides if it needs to defrost , or cycle off due to coldness reached .
Posted on Oct 11, 2009
  • 118 Answers
SOURCE: LG FRIDGE,, fan not working or is thermostat faulty?
fan bad or not defrosting look for ice build up behind panel by fan
Posted on Oct 26, 2009
How many thermostats on a defy frost free, upright, double door fridge freezer
There is on on the freezer side and another on the fridge side..
Nov 17, 2017 | Frost Refrigerators
What is the horse power of the F350 defy upright freezer
That info. is stamped on the product information tag usually found on a sticky tag or riveted to the frame up front.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 25, 2017 | Freezers
Defy Freezer F350 red alarm . What can cause it to alarm.
door not sealing properly check for fold or door alignment
Feb 22, 2017 | Freezers
My double door firge frezeer is not icing and the red alarm button is alarming all the time
Glori,
you mite need to replace your thermostat,...... the alarm button is
telling u that your fridge is not cold enough, there is also probably another prob but u need to b a electrician to sort it on the top of fridge there is a panel,.. under that there is a fusible link if one blows it will need to b replaced its soldered in no job for u unless ur a electrician hope this helps
Oct 24, 2013 | Red Defy Helmet Youth 2012
Model 720EF. Model No 059040415. The grill will not work. The top oven is still working but the grill light or fan will not come on at all. Stoves have told me over the phone that it could be the...
First things first. The top oven lights ONLY come on when the top oven is switched on. Operating the grill DOES NOT turn the lights on. If you wish to see what you are grilling, you have to turn the top oven control knob on to its first position as well as turning the grill on.
Secondly, the grill only works when the door is open. The grill does not work when you shut the door. When you open and shut the door, you should be able to hear the microswitch operating. It is located in the right hand side of the cooker, between the inner and outer panels - you cannot see it. I haven't seen the switch first hand but they normally come with an arm that contacts the door mechanism and the door mechanism operating, causes the arm to move, which causes a button on the switch to move and make the circuit. It has been known for the arm on the microswitch to bend with use so it no longer works correctly.
If you have checked all above and you hear the switch operating, then it could have failed. They are quite common, so if you can't get one from STOVES, try espares or someone like Maplin or RadioSpares.
The get to the microswitch you have to take the oven out of the housing and then take the right hand panel off. You should then be able to see it and check its operation.
All the best
Jul 26, 2011 | Stoves 720EF Electric Double Oven
DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Sep 11, 2009 | Freezers
I have a GE side by side refrigerator GSS22JEMB BB. The defroster heater was replaced. How do I know if the defroster is working properly. Can I manually manually make the fridge go into defrost mode? Also...
To go into defrost manually : Remove the 10"X13" panel from the back of the fridge . You will see a plug with 3 larger wires going to it . Unplug this plug ( UNPLUG THE REFRIGERATOR FIRST ) . The blue receptical will look like this wire#1,wire#2, space , wire#3 . Use an insulated jumper inserted into the receptical to wire #2 and #3 . Plug refrigerator back in . You will be able to see the glow from the defrost heater if the freezer is cold enough and the bimetal is good .
Some models , when the freezer door opens , the fan will keep running and others , the fan will stop , until the door is closed .
There will be a slight stream of cold air at the top of refrigerator section due to the fact , that if it was a larger stream , food would freeze on the top shelf of the refrigerator section .
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 14, 2009 | Refrigerators
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
