Question about Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Step down transformer
Hi, I just bought an ice cream maker from USA for India but the voltage is 110v - 220v on the machine. Since I live in India which uses 220v - 240v which adapter should I use for my machine?
2 Suggested Answers
  • 10 Answers
SOURCE: hi, i bought cuisinart ice-21
It sounds like the step-down transformer is running just beyond its capacity, and so shuts down when the load gets too high. A load peek may also occur when cooler turns on.
Can you please post the power ratings of both your Maker and the transformer please ( AMPs or Watts or VA)
Isaac
Posted on Jan 31, 2011
Why does machine have 2 cords and 2 cord caps
Because of the amount of energy it requires. It was set up for a non 220V location. Plug each cord set into a different circuit.
Apr 16, 2015 | Taylor Crown C713-27 Soft Serve Ice Cream...
I have bought cuisine art icecream maker ice 21 Its 120 volt and 50 watts im living in india it has 240 v now i need step down transfromer how many watts should i buy ? And can u pls fwd me the link from...
The motor will run hot because the AC power is only 50 cycles . The motor needs 60 cycles so heat is generated by the motor. If you still want to get a step down transformer, get one that will supply 50 watts or more. The more watts the better.
Aug 08, 2017 | Ice Cream Makers
Delonghi problems
Mains voltage in Australia is 230V 50Hz. Travellers from most nations in Asia, Africa and Europe should have appliances that work on the same mains voltage as Australia - therefore you will not need a voltage converter. Notable exceptions to this are Japan, USA and Canada which uses 100/120V 50/60Hz.
If your country does not use appliances within the 230V 50Hz mains voltage range, you will need to purchase a voltage converter. This will transform the voltage from the power outlet into one your appliance can use. You will also need a power adapter.
Dec 18, 2013 | DeLonghi Gelato GM6000 Ice Cream Maker
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions ' eHow.co.uk http://www.ehow.co.uk/how_7784888_ge-ice-cream-maker-instructions.html#ixzz1ahXwP2GR
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    Hi, i bought cuisinart ice-21 ice cream maker from amazon.com as im from Malaysia. I have used a voltage step down transformer as the voltage in malaysia is 240V when i use the ice cream maker. But...
    Isaac
    Jan 31, 2011 | Cuisinart ICE-21 Ice Cream Maker
    Taylor 8756. Electrical service too high???
    This is your problem! There are solutions available for this problem. I recomend a Buck and Boost Transformer. You will have to purchase one sized correctly for your machine. Be prepared to spend a little money as they are not exactly cheap. Get the transformer from a local electrical supply company. Take them all the information on the data plate and your existing voltage readings. They should be able to determine what you need. The buck and boost can be wired to "buck" down the voltage to a more suitable voltage for your machine. You need to be within the electrical range stated on the machine or you will continue losing controls etc. This can be very expensive as well. Please note: you will need a skilled technician to wire and install the buck and boost transformer. They can be complicated.
    May 12, 2010 | Taylor 632-33 Ice Cream Maker
    I bought a used taylor ice cream machine. It is model number 8756-27 and it was manufactured in 1987. It is a water cooled machine ... Do you know how much water it uses daily?
    You use ICE, not water and then rock salt is added over the ice to lower the temperature for making the ice cream.
    The salt hastens the melting of the ice and thus lowers the temperature.
    Nov 13, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
    I have the DAK Gellatissimo machine with Broken Belt as well
    The following Gates belt will work. Its called Poly power chain belt which is metric and just under 12 inches with 60 teeth. Just Google the number and you will find several suppliers online. Costs around $24 which is cheap to fix such a great machine.
    Product # 5MGT-300-09
    Oct 03, 2009 | Musso Stainless Steel Pola Ice Cream Maker
    Cuisinart ICE-30BC 2 Quart Ice Cream Maker Logo
    65 people viewed this question
    Top Cuisinart Ice Cream Makers Experts
    Jay Finke
    Jay Finke
    Oloyede Monsuru
    Ruth summersides
    Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
