CLE-979 remote TV/STB issue
Dear Profs, My remote control CLE-979 has starting to function in a way not clear to me. When i press SEL button, STB button only blinks and does not switch to TV. When i press buttons, for some butons STB blinks for some TV. but i cannot operate TV. can anyone advise me either how to restart (if it works) or how to repair my control's mind :) thank you!
  • 6 Answers
SOURCE: Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Posted on Jan 05, 2009
  • 458 Answers
SOURCE: pressed 'D/A' button on remote and tv and tv has stopped working
This is the Digital/Analogue input choice. The TV has probably locked up due to a signal failure, try switching the TV off from the mains electical plug, leaving it for 30 seconds, then plug the TV back into the mains socket & try switching it back on.
Posted on Jul 08, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
dcramer531
  • 1654 Answers
SOURCE: My child pressed buttons on
These instructions should get your set unlocked, if not there is a number to contact omni for technical support, some times these locks may be a software issue.
  • Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
  • 2
    Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
  • 3
    Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
  • 4
    Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
  • I hope this resolves your issue.
    Posted on May 21, 2011
    Kensolutions
    • 455 Answers
    SOURCE: some buttons on my cle
    I understood that the buttons on the Remote are not working as expected. This seems to be an issue with the Remote. Make sure that the battery in the Remote is fully charged. You can also try resetting the Remote and check if it works. To reset the Remote, remove the batteries from the Remote, press each button twice in the Remote and re-insert the battery after 1 minute. This should resolve the issue. If the issue is not resolved, then it is required to get the Remote serviced.
    Thanks for contacting FixYa.
    Posted on Jul 22, 2011
    Need code for ProScan universal remote
    Proscan HDTV Codes = 1000
    Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
    Proscan DVD Codes = 2118, 2144, 2205, 2319
    Proscan VCR Codes = 3000
    ON MOST REMOTES:
    1. Turn on the TV.
    2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
    3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
    4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
    5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
    Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
    Nov 22, 2016 | Proscan Televison & Video
    I need to program my telus remote to turn my 46"
    Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
    Remote should now work with tv.
    To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
    Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
    All should be good.
    If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
    Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
    Manual tuning of Hitachi cle-942 tv
    Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
    Aug 20, 2009 | Hitachi HL01453 Remote Control
    How do u program Bush DFTA13HD STB TV buttons
    The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
    1. Press STUDY key until Red LED remains lit (for about 3 seconds)
    2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
    3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
    4. Now the Power key can turn on/off TV/s power
    5. Repeat settings of learning for the other keys
    You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
    Note:
    1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
    2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
    Jul 19, 2009 | Televison & Video
    Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
    I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
    • Press and hold STB
    • While holding STB, press OK
    • Release both keys, wait for device keys to blink twice
    • Press 9-0-0. The STB key will blink three times
    Then I reprogrammed the TV control.
    • Turn your television on
    • Press STB to enter Set Top Box mode
    • Press and hold TV
    • While holding TV, press OK
    • Press 1-1-2-7. This is one of the Sony TV codes
    After this, the volume + and - worked to control the TV.
    • Program any other devices, such as DVD using procedure similar to above.
    I hope this works for you.
    Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Jan 05, 2009 | Samsung LN19A330J LCD TV
    Televison & Video Logo
    18 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
