Question about Danby 16.7 cu. ft. / 473 liter Upright Freezer DUF1700W
Noise Problem We purchased the above-mentioned Danby Upright Freezer about 3 years ago and are very satisfied with it. However, for the past week or so, it has become very noisy. When we open the freezer door the noise is quite loud and when the door is closed it is still noisy most of the time but nowhere as noisy as when we open the door. What could be the reason for this noise? Is there anything we should or should not be doing? Hope to hear from you soon. Thank you in advance, Ab
  • 63 Answers
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Posted on Aug 29, 2007
SOURCE:
I have a Danby DUF808WE upright freezer. It works for a while (days/weeks)then stops. If I wack it on the top it starts up again and runs again. What do you think the problem is?
In that model the Temperature Control often is the culprit.
When the freezer gets very cold it shuts off.
The because it is not running it gets warmer and will start to work again.
I would perhaps focus on the Temperature Control.
Aug 22, 2018 | Danby Freezers
4.7 cu ft chest freezer dead
Compressor not starting, usually cheaper to get new chest freezer, rather than replace compressor
Oct 11, 2015 | Danby Freezers
Why is the top of freezer frosting up
The door gasket is leaking around the top of the door. Air getting in past the gasket condenses in the freezer causing the ice build-up.
Sep 07, 2014 | Freezers
Danby upright freezer plugged in a few hours ago, but coils on back are hot
If you are talking about the black condenser coli on the back of the fridge it is hot because the refrigerant is pulling all of the heat out of the fridge and trying to deposit it outside of the box. This is called hot box pull down. When the temperature inside the fridge comes down and you have product in it the coil on the back will become much cooler during operation. So if you are wondering it is nothing to be worried about, perfectly normal.
Aug 29, 2014 | Danby 10.4 cu. ft. / 294 liter Upright...
The temperature alarm goes off randomly. It remained silent for 6-10 hours after I turned it on originally then started to sound. I shut the alarm off for 10-12 hours then turned it on again. Once more it...
If you just purchased the freezer 3 weeks ago, I would be calling the store and or the manufacturer, and have them send out a service man to fix it or replace it.
May 02, 2017 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
I would like to register my new freezer
It can be done online at
https://www.danby.com/registration.php?ln=CE& (copy and paste)
If you have purchased an extended warranty you will need to go to this page to activate the extended warranty.
https://www.danby.com/warranty.php?ln=CE&tip=EXT
Hope this helps
Dec 04, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer making noise & left side of the freezer (on outside is very warm to touch)
Sounds like the freezer evapurator fan... they make noise on and off at times when bears are wore... Thats about the only thing that can make noise inthe area ur talking about.. if noise comes back listen where the freezer fan is.. is most liklly the problem
Nov 02, 2007 | Freezers
Danby 16.7 cu. ft. / 473 liter Upright Freezer DUF1700W Logo
722 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Bruce Denton
kfinlay1969
Level 1 Expert
Are you a Danby Freezer Expert? Answer questions, earn points and help others
