My Landry machin keep spaning with out stop and it
My Landry machin keep spaning with out stop and it looks like it be come to the a part when it must dry the Colase doesn't do it and keep shoing in the small screen it trying to get the water out of the michan and when I open the laid I seen water in the pattem of the machin not a whole lot can you tell me what to do please do I have to call for service or no I'm watting for you replay thanks my machin brand is maytag Neptune TL model no fav9800aww. Serial. No 11417346EE. 120 V . 60Hz
    Sergeant:
  • 342 Answers
The filter on the spinner pump has become blocked. At the bottom of the machine at the front the panel should come off.There will be a filter to remove and unblock. If in doubt call the manufacturer for a service call.
Posted on Jul 22, 2013
SOURCE: Maytag Neptune TL
Lr stands for motor not running properly.  Solution says to call for service.
Posted on May 12, 2008
  • 96 Answers
SOURCE: maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
Posted on Jun 08, 2008
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune TL Stops
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Posted on Dec 15, 2008
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune Tl FAV6800A stuck in wash cycle
Hello rockhead255 ,
I'm an owner like you and will try to help.
Error code 10 states Unbalance or cabinet hit detected during final spin, which prevented the spinner from exceeding 500 rpm
Did you notice if you took some large tub swings as the washer tried to spin up?
I suspect a Clutch malfunction. Pump the water out of the tub with the Board Output Test with the drain pump in service mode. With the wash tub empty open the lid and see if you can rotate the wash basket CCW with one finger. You mentioned “”Tub does not turn by hand””. Is that in the CCW direction?
You should be able to rotate the wash basket with your pinky finger with very little force. The wash basket will not rotate CW. What amount of rotational resistance do you detect in the CCW direction? With the error 10 reported I would drop the clutch out of the machine per my step by step procedure at this post. Try the One-Way roller clutch bearing clean up and re-lube as I discuss in that post and see if you can restore the machine to normal Spin operation. Once you drop the clutch out of the machine we will have a better feel for the issue.
You can try the TDS check in the SM but I feel it is a Clutch issue at this point of troubleshooting. Good troubleshooting using the machines diag code listing.
Post back if you havd need additional questions or help.
Rich
Posted on Sep 28, 2009
Testimonial: "Thanks for the answer, I will try these when I get home this afternoon."
SOURCE: Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Posted on Dec 14, 2009
My beko wb 6004 ns doesn't spinning to dry the clothes
the issue is in the timer . have a qualified technician change it with a new one . thanks .
Jun 14, 2013 | Washing Machines
Doesn't want to dry.
More information! Im guessing its just blowing cold air?? If so all fire risk products such as this a fitted with safety switches. (High temperature cut cut) as your dryer looks fairly now im guessing the element is ok! So if its powering up and just not drying! Id put my money on a faulty thermostat. ... hope this helps
Jan 22, 2013 | Lands Phones
FX SHO YAMAHA 2012. few hours, stops some times, at idle not always
Im not very agree either but i would tell them you have a lemon and want a replacement before they say too much time has passed.
Aug 14, 2017 | Boating
Hp 7410: Error msg: Remove and check color cartridge. Is this a deathnell for this machine? I cannot seem to get past it even after removing and replacing.
There are several possible issues causing the problem. The color cartridge could be faulty. The contacts on the cartridge and the associated contacts inside the printer may be dirty. Finally, the cartridge chute may be damaged or printer may need service.
You can try a new HP cartridge. Next try cleaning the contacts with distilled (or bottled water) and Q-tips or lint free cloth. With the printer on, open the lid and remove the cartridges when they stop moving. Disconnect the power cord from the printer to stop the machine in the open state. Clean the cartridge contacts and the matching contacts in the machine. Dry the contacts with a new Q-tip or wait 10 minutes before replacing the cartridges. See http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423559&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=391194 for pictures. Then close the cover and reconnect power cord. You can repeat the cleaning step if it doesn't solve the problem.
If this doesn't work, look at the cartridge chute area to see if the spring is dislodged or the tab is broken. Again see the link above. In that case, the unit needs service. If it is under warranty, contact HP. Otherwise, decide if it is worth the repair cost.
I hope this helps.
Aug 17, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Craftsman 179220 Canister Wet/Dry Vacuum
Maybe open the motor casing and look for an overheat reset button. If it doesn't have one, check for voltage at the wires coming directly out of the motor. If it has power there and no reset switch, then the motor needs replaced or rebuilt.
Jul 18, 2012 | Vacuums
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
Hello! We have Ariston AML 125. We've been using it for 5 years now and before we didn't have any problem. But just a couple of days, the drying program doesn't work properly. The washing...
Sorry but you have not mentioned whether you were able to check the function of the drain motor itself- it could be blocked/jammed which would account for the machine not stopping (still trying to drain but being unsuccessful). Soaked clothes take ages to dry in a dryer!
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 27, 2011 | Washing Machines
When I turn on my Canon ir 1018 it doesn't stop heating. i.e it doesn't get ready for photocopying. It keeps on turning but doesn't stop in order to get ready.
This sounds like a faulty fuser assy. Basically the machine is warming up but nevers gets to temperature. The lamp has probably blown and for some reason it is not giving any error.
I would put a new fuser in and all should be well.
Jul 19, 2011 | Canon IR1018J Black and White Copier
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
