Zanussi FAE1226
All lights flash during machine wash and when the machine is empty
  • 183 Answers
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Posted on Aug 30, 2007
  • 1294 Answers
SOURCE: Zanussi ZWD1471W Washer Dryer error codes help please!
Click on Zanussi (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 05, 2007
SOURCE: ZANUSSI WASHING MACHINE
seems to be a problem with the filter. was with mine.. one thing i always forget to clean it regularly.
Be careful when open the little hatch thingie , there will be water coming out . so prepare with a bakingtray and kitchen towels. and open it SLOWLY!!! so the water doesnt totally soak the floor.
then clean clogged up filter. at least that solved the problem in my case, hope it works
Posted on Dec 29, 2007
bozcro
  • 867 Answers
SOURCE: Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
Posted on Dec 11, 2009
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Posted on Mar 14, 2010
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Dec 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
Zanussi FJ1254 W - Machine does not fill
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
Dec 01, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
May 30, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Oct 23, 2006 | Zanussi FLE1416W Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
