Question about Electronics - Others
Download the Swivel Pro Flash Drive Formatting Tool (Version 2.0.0.0) and Imation Flash Login 3.0.0.0.exe
Download Imation Flash Login 3.0.0.0.exe
Beni S-P
  • 1006 Answers
SOURCE: USB imation drive 1 gig
Usb is infected with virus and if u cant re-write it with binary languange just buy new
Posted on Oct 27, 2007
boogschd
  • 84 Answers
SOURCE: Imation 512mb flash drive
you need a driver for that to work. i think...
Posted on Nov 02, 2007
  • 30 Answers
SOURCE: Imation Swivel Flash Drive Cant detect
Check it another computer. If drive is still powerless, then you most likely have a failed flash drive.
Posted on Mar 15, 2008
parasgumbhir
  • 179 Answers
SOURCE: imation 2gb pen drive is
VIRUS OR TROJAN INFECTIONS:
Virus or trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert thepen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
CORRUPTED FLASH CHIPS ON PEN DRIVE:
If the pen drive is not detected at all, or shows a less capacity, then there are high chances that its a chipcorruption. Flash chips are the actual hardware components that save the data. A physical or electrical or electromagnetic damage to these chips make the pen drive faulty. This can happen because of voltage fluctuations and faulty USB ports. In such case, get the flash drive replaced if its under warranty as it can not be fixed otherwise.
FAKE PEN DRIVES:
Sounds a bit un-believable but true. There are a lot of pen drives in the market which are of very cheap quality which are fake copies of some known brands. Beware of such pen-drives. Always purchase pen-drives or memory-cards from a reliable source with bill and warranty to avoid any mess later.
Posted on Jan 15, 2011
puertobori
  • 7733 Answers
SOURCE: If i were delete the“Imation Flash Logout.exe”
Espanol? Vuelve y postea el problema y trata de conseguirme y me solictas la ayuda puede ser por solo $3.
Posted on Jan 23, 2011
My louck flash is formated and now i can not use the space what do i do?
Your Imation Swivel Flash Drive comes formatted and ready to use right out of the box.
If you will be using the drive exclusively with Macintosh computers, do not format the Imation Swivel Flash Drive. The formatting message appears if your Macintosh has not yet been set up to read Windows-formatted files. Refer to your Mac's user manual to learn how to enable Windows file read functionality.
Also, be aware that when you format your Imation Swivel Flash Drive with NTFS, you will not be able to store as much data as your would without formatting. The format file used by NTFS will use some of the available space on the Flash drive - for instance, on a 128MB Imation Swivel Flash Drive, you may lose up to 8MB to the NTFS format files.
How do I format my Imation USB 2.0 Swivel Flash Drive in Windows? Your drive must be set up as a single public partition, since neither Windows Explorer nor the Macintosh OS will recognize a password protected partition.
To format the drive in Windows:
  • Go to My Computer
  • Locate the corresponding drive letter for the Swivel Flash drive (i.e. removable drive F)
  • Right click
  • Choose Format from the menu
A dialog box will come up and allow you to format your Swivel Flash Drive. Depending on your operating system, you can choose to format the drive in FAT, FAT32, or NTFS.
How to I remove or resize a partition on my Imation Swivel Pro Flash Drive? To resize or remove a secure partition, you will need to do the following:
  • Open the Flash Manager software on your hard drive
  • Choose Create a partition
  • Move the slider to zero (0)
Why don't I see a drive letter for my Imation Swivel Flash Drive?
This problem occurs if you map a network drive to the first available drive letter following the drive letters for the local volumes and CD/DVD drives. When you install a new device or volume, a software called Mount Manager tries to assign drive letters to the new volumes. But since the software does not recognize mapped drive letters, it assigns the next available local drive letter to the new device. This causes a collision with the existing mapped network drive.
Since the problem is related to your Microsoft operating system, they are your best source for resolving this issue. For more information, click here.
Dec 05, 2010 | TDK (CD-RW74HSFXS5) Storage Media
My computer detects 4 Gb pendrive (S/N 5282015959 & model TS4GJFV30 but does not open.In properties shows zero bytes but device full
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
3.b) Format pendrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 30, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Memory stick pro duo
1. Download this tool:
2. Format stick pro duo
Jan 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Unable to format
2. Format
Jan 27, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
I deleted Photos from my 2G Memory Stick Duo on my computer, now the camera says there are no images but has only 100mb memory space available
2. Format Memory Stick Duo
Jan 25, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
How to remove write protect on my usb flash drive?
2. Format flash drive
Nov 27, 2009 | iLO (2 GB) MP3 Player
Formatting
2. Format
Dec 22, 2008 | SanDisk Extreme III 2GB Secure Digital...
2g attache optima pro black/amber went to write protected...how do I fix it?
2. Format
Dec 10, 2008 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
