Question about Whirlpool duet Washing Machines
8182862 Needed to replace inlet water valve (part #8182862 on Whirlpool Duet Model ghw300pw4. Ordered part only to find that wire connectors are incompatible. Machine wiring has two different shaped male connectors; one fits. The other male connector is shaped differently and won't fit into the female wiring receptacle on the replacement 8182862. Checked images of other online inlet water valved--not able to find one that has a compatible shape. What to do? Had this Whirlpool Duet bout 8 years.
  • Whirlpool Master
  • 744 Answers
You can change the connectors on the wiring loom there are only two wires per valve
this video might help
Posted on Jul 22, 2013
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet GHW9100 LW1 Front Loading
Probably a good assessment. I wasn't trying to second guess your repairman. I just wanted to make sure you were able to have the knowledge to eliminate some of the possibilities yourself. That way, you feel a little more confident that you're getting the correct repair. It sounds like the solenoid is probably clogged or scaled up from sediment. Let me know how things turn out for you.
Posted on Jun 01, 2008
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune Part Change?
I haven’t had to change the water inlet valve but is this the valve assembly you purchased?
http://www.repairclinic.com/SSPartDetail.aspx?s=t-fav6800aww-%3d%3dc292i1032809&PartID=1032809
It looks like they throw in an install instruction sheet at this parts supplier site. If you have this do they speak to adapting the wiring harness to the H/C valve assembly. I’m sure you are not lucky enough to have male spade connections on you replacement inlet valve. If they are spade lugs this would be a piece of cake to interface too. Looks like a molded connector on the inlet valve to terminate the 120VAC power to the valve assembly.
I called the supplier above and if your machine starts with serial number 18 or above you need to purchase an upper LED wiring harness p/n 1185286 $55 to interface to the replacement H/C valve you purchased. Or you can purchase p/n 1404313 wiring info for $7.50 for the DIY’er. I know this is a bit frustrating. I don’t have the valve in hand so I can’t offer a quick solution. I’m willing to bet the wiring harness they are selling for $55 is nothing more than a cable with proper female/male mating connector transitions to interface to the factory 120VAC connections to the inlet valve. If my water inlet valve fails I would be in the same boat as you but I would make up an interface cable before spending $55. Maybe a more knowledgeable forum member can offer a better solution. Good luck to you.
Posted on Feb 19, 2009
  • 235 Answers
SOURCE: Took water intake valve assembly out to replace -
Try it the way you said if it that doesn't work reverse connections. No damage can be done. You'll get cold water if asking for hot and vice versa.
Posted on Jul 05, 2009
  • 65 Answers
SOURCE: how to replace a inlet water valve on top loading
These aren't to bad but hopefully I can clairify well enough for you to follow. You will need a phillips screwdriver, a flat head screwdriver and a 1/4 inch driver (or socket). Slide the unit out and disconnect the water lines and unplug the washer all together. Now stand directly in front of the washer and look at your control panel. That whole console with the 3 selector switches and timer are going to be flipped upside down, backwards off the cabinet. If you look to the left and right of that console you will see a plastic end cap (or ears) on each end of the panel those knobs and the timer are stuck in. You need to look to the backside of the washer at both of those plastic end caps and you will see a phillips screw pointing towards the ground at a slight angle. They should be the only phillips screws in the end cap and they have a special tab right above them to keep them from coming out with vibration. Use your phillips to push in the tab while unscrewing these 2 screw (one in each end cap). Once unscrewed pull the whole panel forward about 1/4 inch and it should release and flip backwards.
If you got it then hard parts over. K, now we work on the area you just exposed by moving the console. Unplug the connector to the lid switch by pulling up locking tab and pulling out the wire connector. You should see 2 brass clips locking the rear panel to the cabinet. Examine them before taking them out so you will be able to pop them back in the same way they are coming out. Use the flat head to slide into the cabinet part of the brass clip and pry to the back of the washer. It should go down straight and pry to the back. You have just freed the whole cabinet front but don't take it all the way off because it can be tricky to get back on. Just lean the back panel out so you can access the valve for replacing and you got it.
Posted on Jan 23, 2010
quatlew
  • 139 Answers
SOURCE: Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Posted on Mar 15, 2010
The water dispenser will not shut off right away when the glass is removed.
HI. this will occur when the water inlet valve is clogged with debris. this will cause the valve to stick, or not close properly. follow the procedure below to inspect the valve for mechanical damage. replace if needed.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Nov 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator water dispenser won't stop after being pressed and constantly drips after water source is turned off. Whirlpool Model #ED22PQXFW01 SN #SJ4236632
Hi. This will usually be the fault of the water inlet valve. The solenoid based valve may have debris building up, thus, causing the valve not to close properly, after usage. Kindly, follow the procedure below to confirm the damage, replace the valve, if needed.
Nov 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The icemaker isn't working. The water line is hooked up and working fine when I want to get water, but the line isn't feeding water to the icemaker in the freezer.
HI. testing is needed at this time. There are some issues that concern the operational value of the inlet assembly. check the lines to make sure that they are not frozen. If the line that feeds the ice-maker is ok, and not frozen, proceed with the testing of the inlet assembly.
Nov 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water dispenser from my whirlpool is constantly leaking a lot of water. Started every 1/2 hour leaking some water a time but now is a cosntant stream
You need to get access to the following instide . On the bottom of the faceplate there should be two small pry spots to remove faceplate. once the faceplate is removed you should have acess to the inside. Check for the leaks and seal them.
Thanks for contacting Fixya.com
Nov 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water not dispensing in side by side Whirlpool refrigerator
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source. Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced. Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Jul 22, 2009 | Whirlpool GS6NBEXR Side by Side...
WHIRLPOOL FRIDGE S/S MODEL #ED2FHGXKQ00
Hi Yamanayeemi,
"Dont forget to rate my solution to your STOVE!"- Fixya or helpful?
Before attempting any testing or repairs. unplug your fridge.safety first.! avoiding an electrical shock hazard.
It might likely be your water inlet valve that is bad , corroded or clogged.
Does my suggestions help to solve your problem?
Aug 01, 2008 | Kitchen Ranges
Can't get cold water to work
You may have a defective water inlet valve. This is where the washer inlet hoses connect to . The water ports are controlled by an electrical solenoid, which sometimes fail. If you wish to replace the valve, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. You can find the part you need as item #1 under the "Dispenser Parts" heading (part #8182862). You can also find it at repairclinic.com as item #906483 for slightly less. I hope this information is helpful to you. If you need further advice, please post back and let me know.
PS Try turning off the water and disconnecting the cold water hose & check the sediment screen inside the valve. You may be able to clean the valve screen and avoid replacement altogether.
May 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer WFW9200SQ00 display F20
"F20" is a water inlet problem. This indicates that you have no water or insufficient water supply. What Whirlpool recommends to do is unplug the washer and check your water inlet screens to ensure they are not clogged, check the inlet hoses for kinks, and to make sure your taps are turned on (duh! I know it sounds stupid, but I've seen it before).
To check the water inlet screens you will need to turn off the water supply and disconnect the hoses where they connect to the back of the washer. The inlet screens are located inside the tap fittings and sometimes will collect with sediment and rust depending on your water source. Some hoses also have sediment screens. Check them as well if you have them. Use cotton swabs to clean the screens, thoroughly.
Checking the hoses and taps is self-explanatory. The water supply coming into the washer should be at least 10-25 psi. Insufficient water pressure can cause problems with slow fills and/or error codes due to insufficient pressure. If you haven't had any problems before, I would suspect dirty inlet screens and/or a inlet valve failure.
If you need to replace the water inlet valve, searspartsdirect.com carries the part. Just type in your model number in the Search menu and look for item #1 under the "Dispenser Parts" heading (part #8182862). The part runs about $52.00.
I hope this helps you. If you need further assistance, please post back with any questions/concerns you may have.
Apr 16, 2008 | Washing Machines
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
