Epson Business Inkjet B310N Network  Color 37 ppm Mono  37 ppm Color  5760 x 1440 dpi   Printer Logo
Anonymous Posted on Jul 22, 2013
Error 0x50 not ready to print
Martin Smallridge
Level 3:
  • Epson Master 419 Answers
  • Posted on Jul 31, 2013
Martin Smallridge
Epson Master
Level 3:
Answers
419
Questions
0
Helped
289767
Points
1120
This FAQ article may help...
http://www.octoink.co.uk/kb/questions/127/Epson+Error+0x50
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
3answers
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
How to change wheel of pm 210
Please tell me the Epson pm 210 printer error 0x50 information and if you need tech support so call us :1-855-383-7237 our tech team was resolve your issues.
1helpful
0x50
anybody help please
my B310N printer shows on panel restart printer 0x50
tried several times .
waste pad also done with re setter
how to solve this problem
HEMANT
1helpful
HP Laser Jet CM1312 MFP internal error 0x50
Did the Ox50 error have any additional information with it or happen only with network printing?
Frequently, this error is associated with a font being sent to the printer with the PCL 6 (printer control language). The temporary fix is to turn the printer off and then on (to clear its memory).
Next try going to the Printing preferences by right clicking on the printer in the Printers control panel. (For XP, click Start > Control Panel > Printers and Faxes. In Win7, click Start > Devices and Printers (or Start > Control Panel > Hardware and Sound > View Devices and Printers). Then right click on the LaserJet CM1312 icon and select the Printing Preferences. Go to the Advanced tab and change the Print Data Optimization option from Advanced to Optimize for Text and Vector.
If this doesn't work, uninstall the printer (right click again). Then reinstall the network printer using the PCL 5 universal printer driver. All of the drivers are available here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3558903&prodTypeId=18972&prodSeriesId=3558902&swLang=8&taskId=135&swEnvOID=4063 . The PCL 5 driver is the last one in that section.
If the printer is connected to one computer via a USB connection and then that computer is the printer server for the others, you may need to disconnect USB cable and uninstall both the universal print driver and the regular printer driver. Then reinstall them in the opposite order.
I hope this helps. Please add additional information about the error for more assistance.
(PCL 6 has some issues.)
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
2answers
System we have here at work has BSOD 2x with xeskmdrv.dll error 50 blue screen - lookin for reason/solution on this
As you probably know, this is a Xerox printer module. Below is more info on Stop 50 but in general, you might try reinstalling the printer with the latest drivers.
Stop 0x00000050 or PAGE_FAULT_IN_NONPAGED_AREA
The Stop 0x50 message indicates that requested data was not in memory. The system generates an exception error when using a reference to an invalid system memory address. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause Stop 0x50 messages.
Possible Resolutions:
• If you added new hardware recently, remove and replace the hardware to determine if it is causing or contributing to the problem. Run diagnostics software supplied by the hardware manufacturer to determine if the component has failed.
• Stop 0x50 messages can also occur after installing faulty drivers or system services. If the file name is listed, you need to disable, remove, or roll back that driver. If not, disable the recently installed service or application to determine if this resolves the error. If this does not resolve the problem, contact the hardware manufacturer for updates. Using updated drivers and software is especially important for network interface cards, video adapters, backup programs, multimedia applications, antivirus scanners, and CD mastering tools. If an updated driver is not available, attempt to use a driver from a similar device in the same family. For example, if printing to a Model 1100C printer causes Stop 0x50 errors, using a printer driver meant for a Model 1100A or Model 1000 might temporarily resolve the problem.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
