Question about Archos ARNOVA 7b G3
How to bypass password for arnova 7h g3 - Archos ARNOVA 7b G3
Arnova 7k g3 wont charge
You probably destroyed the port plate of the charger. You should check if it is bent or dented and if they are the price to get it fixed is $50-$150
Jan 20, 2014 | Archos Arnova 7 G3 Tablet
I forgot my password in arnova 7bg3 how can i open it??
Well you cant, you will need to do a factory reset, when the device is of hold down the power button and volume up and it should bring you to a recovery menu where you can factory reset it and get rid of the password
Thanks
Aug 06, 2013 | Archos ARNOVA 7b G3
Arnova 10 g3 won't turn on
i see that you are using a universal power adapter, do you have the voltage set to the proper voltage that the unit requires?
I have one of those radioshack universal power adapters.
Based on the fact that it says that it can charge via USB, you would need to have it set to 5 volts. if you have it set to anything different, you are risking damaging the unit.
Try a different power adapter as an alternate step. If that doesnt work, come back and I will try to help you further.
Feb 27, 2013 | Tablets & eReaders
Cannot connect my arnova 7d g3 to the internet keeps saying authentication problem. can anyone help
You don't know the password to your wi-fi protected setup. They changed the password when they changed your equipment. Ensure you have the correct password and that you are not too far from the access point.
Jan 20, 2013 | Tablets & eReaders
How to put arnova 7 g3 in recovery mode
make sure the tablet is off, then push and hold the reset button(small hole on same side as power button), while holding the reset down push and hold the power button. continue holding both buttons until you see the "Arnova" flash screen, then release the two buttons. this should put you in recovery/download mode... it is not touch enabled though, and there are no physical buttons on the tablet, so you will most likely need the Rockchip flashing tool. Good luck
Jan 19, 2013 | Archos ARNOVA 7b G3
My arnova tablet is blocked and unable to log on
either you will have to hack it or wait for a while till it resets
Dec 31, 2012 | Archos ARNOVA 10b G3 8GB 10" Capacitive...
Arnova locked
wachtwoord forgotten
Nov 12, 2012 | Archos ARNOVA 7b G3
Archos ARNOVA 7b G3 Logo
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
