Electolux ewf1074 dropped drum
Drum has dropped and rubs while spinning making horrible noise and leaves plastic shavings in washing!!!
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
tomsat69
  • 219 Answers
SOURCE: Machine does not spin, it only makes a horrible racketing noise
Sound like you have a busted coupler .It is located between the motor and trany.Cheak inbetween .hope i helped.:)
Posted on May 18, 2009
Karthik316
  • 187 Answers
SOURCE: Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Posted on May 22, 2009
  • 235 Answers
SOURCE: makes a horrible noise when spinning out
Changing the belt should help.
Posted on Jul 02, 2009
SOURCE: The washer drum is hitting in the spin cycle.
When you take off the back panel, check to see if both shock absorbers are intact. We were having some problems with our (ATF6000E) Frigidaire front-loader recently too. I noticed that one of the shock absorbers was broken, for about $25 I got a replacement (two of them, I couldn't find just one). It took about 15 minutes to replace. No problems. With mine, though, I think because the drum was moving around, it dislodged some wires which made it stop filling up with water after a few seconds. I did a test and it said E5E. I would check to replace your shock absorbers before doing any more laundry so your machine will still work and not have other problems like mine.
Posted on Sep 11, 2009
My Duet Washer is making loud noise during spin cycle and has plastic shavings, from front tub rubbing i assume.
Hi, it could be your drum bearings are gone the drum would wobble slightly. A way of checking is , machine unplugged put one hand at bottom front and one hand at top front edge and push up and down if it clunks quite badly then your bearings on the drum shaft are needing renewed. You also have a shock absorber for steading the drum this can also fail. The absorber is very hard to compress so if its easy to compress then it needs re-newed.
Dec 29, 2015 | Washing Machines
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washing machine started to make a loud grinding noise and does not rotate to wash nor to spin. after moving the machine i found some plastic shavings under it.
Sounds like the bearings for the drum have or are on the way out. The belt has probably broke or come off.
Depending on the age, cost of new and personal feelings it can be repaired but normally it isn't cost effective, unless the machine cost £500+ ($800+)
Jun 14, 2009 | Washing Machines
Whirlpool front loader washing machine
you see plastic shavings??? thats part of the front tub assy, not a very fun part to change call a professionnal for that one. in the meantime id pop off the lower acess panel and make sure all 4 of the suspension rods are in place and not causing the tub to lay foward and rub
Oct 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Drum dropped
Are you able to lift the inner drum back into position ? If so then the culprit is most likely within the trunnion or spin bearing assemblies. Dis-assembly can be tricky but it is possible to do this yourself.
Jan 01, 2008 | Frigidaire FWS1339A Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
