Question about Mitel 3300 Cx Icp Controller Telephone System 56007114 56007112 T1/e1 Card
Mitel c3300 cx II controller flashing red light
My corded super set 4025 is flashing all lights and says " BOOT 9.3 MAIN 9.4 (c) MITEL 1999. what do I do ?
Your phone has lost communications with the main controller (back room equipment) and is trying to reestablish the communications link and boot up. Try unplugging the phone (line cord) and then plugging it back in. If that doesn't fix it then either the phone is defective or the circuit going from your desk back to the phone equipment room is bad, or the phone has been deprogrammed from the system database. Hope this helps.
Aug 02, 2014 | Mitel Superset 4025 Corded Phone...
Why does the message light not blink when i have messages on my mitel superest 4025 phone
The Message Waiting Indicator lamp on the Mitel SS4025 is set and cleared by the main system controller (back room equipment) and is further dependent on the integration between the system controller and the voice mail server. Depending on the type (age) of Mitel main control, the voice mail could be built-in to the Mitel system itself or a separate stand alone server, such as an Octel (Avaya) system. In any event this problem needs to be reported to your phone system maintenance person. Any competent Mitel System tech should be able to resolve the problem for you quickly.
Jun 18, 2014 | Mitel Superset 4025 Corded Phone...
Canon 580EX II Flash is not firing??
It could be the bad bulb. You need to replace the entire bulb assembly. Canon Speedlite 580EX II MYK Camera Camcorder Repair
Apr 22, 2017 | Canon Cameras
Where can I find an online user manual for the Mitel 5212 IP Phone? Quick reference guide says to go to www.mitel.com, but found nothing there.
I have exchanged the telephone on my desk but cannot get a ring tone or flashing lights for incoming calls?
Nov 08, 2010 | Mitel 5212 IP Phone
I have a Mitel 5220 IP Phone with one of the programming lights flashing red. When I check the server, there is no key assignment, but when I check the phone itself, the button is set to Agent Status Key....
In the phone system, assign something to the button. Then clear it. Did it clear at the phone? If this doesn't clear, I suggest deleting and re-programming the phone.
Oct 27, 2010 | Mitel 5220 IP Phone
I am trying to register my Mitel 5201 IP phone to our mitel system but it is not working. The message indicator light does want to flash anymore, nothing happens when i connect it. Please help!!!
the 5201 set must be registered manually in the phone system. Log into the system. Change the extension. Type the MAC address of the phone in the proper field in the form. The MAC address is located on the bottom of the phone.
Sep 14, 2010 | Mitel 5201 IP Phone
I bought several used mitel superset 4025 phones. When I try to plug them in (we have two phone lines in one jack), the display flashes "waiting for sync" and the lights on the phone flash (in succession...
the Superset 4025 is a digital set that is intended to work with a Mitel telephone system. The port must be programmed and connected to a jack to allow the phone to work. The phone is not intended to be used as a home telephone.
Aug 18, 2010 | Mitel Superset 4025 Corded Phone...
Mitel 5224 keeps flashing message but is no message
This sounds like you have a call back message active on your phone, The callback is a through back to the days before we had Voice-mail, if you wanted a person to call you back you could activate their message light by pressing your message key while the called phone was ringing. To remove the light you would lift your handset and press the message key then select which party you wished to "callback", once the call was answered at the other end the light would be extinguished. Give this a try, I bet you will be surprised at the results.
Jul 16, 2008 | Mitel 5220 IP Phone
Error light on my oki c3300 is flashing new ink and everything looks ok
I had a paper jam on my Oki C3300 and after putting back all the cartridges it flashes green revs up and then goes to error. Also where will I find the error code?
Jun 10, 2008 | Office Equipment & Supplies
Mitel 3300 Cx Icp Controller Telephone System 56007114 56007112 T1/e1 Card Logo
285 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
