Question about Buffalo Technology 320GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD Hard Drive
Buffalo Ministation not flashing or recognized
My buffalo ministation suddenly stopped working. The light will no longer flash and it won't be recognised on any computer, even when using a different connecting cord. Strange thing is that the station is making the usual whirring noises, as if it is operating fine. There is no unusual clicks, just the usual sound. Please help.
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
Posted on Jul 24, 2013
5 Suggested Answers
  • 88 Answers
SOURCE: buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
Posted on Jan 11, 2009
  • 58 Answers
SOURCE: total space problem
The windows use some space for space addresing but not that much
It shoves 149 GB because manufacterers use the terms gigabyte in metric (base ten) way.
IT means 160 GB = 160 * 1000 MB = 160 000 * 1000 KB= 160 000 000 * 1000 Bytes
when you convert that in Gigabyte that computer use (1GB = 1024MB, 1MB = 1024 KB, 1 KB = 1024 Bytes) you get:
160 000 000 000 Bytes = 160 000 000 000 /1024 KB = 156250000 / 1024 MB = 152587,890625 / 1024 GB = 149,011 GB
Posted on Jun 19, 2010
  • 10406 Answers
SOURCE: my usb external Buffalo ministation
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
SOURCE: my buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops gr
My ministation was doing the same, beeping and flashing green light after a light drop on the floor. Soo... I took my ministation usb drive out of the plastic enclosure and smacked it on the table a few times. Plugged it in and it spun back up!! Now my computer recognizes it and everythings working smooth! I assume something with the drive became jammed and the couple smacks loosened the drive head.. Anyway, if all else fails... beat it!
Posted on Apr 17, 2013
My hard drive is not recognized in my mac. The light is blue, neve turns to green
Have you tried to connect the drive to a different computer? You can also try to open Disk Utility (use spotlight search to find it). My guess is it doesn't show up there which means there is a problem with the Buffalo device. The disk is most likely fine, just the Buffalo casing needs to be replaced.
Apr 23, 2014 | Buffalo Technology Buffalo 1TB MiniStation...
Formatting buffalo ministation stealth for mac
Probably the software could not recognize or support the disk type/model
Dec 18, 2013 | Buffalo Technology 1tb Ministation Stealth...
I have had my current Buffalo MiniStation Plus HD-PNTU3 for almost about a year now without an issue or problem but recently it refuses to open on another computer while it works fine on my own. I am
The device probably can with a Buffalo utility/driver disk. The other computer will need these drivers to recognize the device. If you lost the driver disk, you can download them here: http://www.buffalotech.com/support-and-downloads
May 31, 2013 | Buffalo Technology Buffalo MiniStation...
I force ejected my Buffalo Ministation 500 external hard drive and now my computer will not recognize it when it's plugged in. Is there a way to fix it or recover the data on it? There are irrepl
There is a possibility that your hard drive has experienced logical damage due to your hard drive is not visible. In this case to recover your data i would suggest you to use some data recovery software that will get online in both free and paid version.
Mar 01, 2013 | Buffalo Technology Buffalo MiniStation...
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
My buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops green...
Nov 05, 2012 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation hd-pct500u2 won't allow me access to it
Go Here
And you will have to download the CD image and then burn it on to a disk. This would possibly be why you can't see it in your device manager because it doesn't know what it's looking for and how to run it. by downloading, burning it, and then installing it. The computer will then know exactly what the peripheral is and how to recognize it and run it as a hard drive. I sure hope this has helped.
Thanks, Cody
Sep 13, 2012 | Buffalo Jeans Buffalo MiniStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation
Oct 18, 2008 | Buffalo Technology 320GB MINISTATION TURBO...
Open Questions:
recording from an external hard-disk to a DMR Dear Sir or Madam, I have just purchased the DMR-BST835EG Blu-Ray Recorder, which has many attractive features. In fact, I also recommended this product to a friend of mine. My prime intention is to transfer some Internet downloaded .MKV-HD and .MP4-HD movies, presently stored on a Buffalo USB-powered external hard-disk, onto the Panasonic recorder's internal (1TB) hard-disk. However, after registering the said USB-HDD on the DMR, its driver is no longer recognized on my computer...and it has to be re-formatted via the PC, with the result that the Blu-Ray recorder again refuses to copy video files from it. What can I do? This article (the DMR) was purchased, for over EUR 600, from EBay, mainly for the above-stated purpose, repeat: copying the HD films, presently kept on external hard-disks, onto the Panasonic recorder (so as to transfer the files onto Blu-Ray discs later on). Please treat as urgent, as I would like to start using the Panasonic article accordingly, and my friend also needs this information before buying the DMR-BST835EG (too). I earnestly await your reply. Thanks in anticipation for your time and attention. Best regards, Ivan Micallef P.S.: Is there some firmware update which could enable the USB-HDD >> HDD (1 Terabyte) recording ? This is an option which should be possible, also according to the DMR's "Copy Video" menu. ; According to various website blogs, many other clients are facing the same problem - what we are askingfor is for the elimination of the USB-HDD registration request. ; Preferably, the external hard-disk accepted/recognized by the Panasonic DMR should remain in the NTFS format and not changed to the FAT32 system. Thanks again.
Mar 13, 2014 | Buffalo Technology 320GB MINISTATION TURBO...
See all Buffalo Technology 320GB MINISTATION TURBO USB 2.0 Questions
Buffalo Technology 320GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD Hard Drive Logo
298 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
