Question about Panasonic Lumix Cameras
No battery power remains - Lumix Panasonic Cameras
After charging overnight the screen was blank the next morning and remained so
try this. take power supply out,take battery out,hold the power button for a couple of minuets ( this will drain remaining power from the board ) now reinsert battery and power . see if it boots ..hope this helps
Apr 24, 2015 | Computers & Internet
Lenovo z570 not powering on
Measure the voltage at the AC Adapter plug, and see if it is within 5-10% of the rated voltage. If the voltage is not correct, then the battery will most likely not be charging, and the system will drain the battery and die in the middle of what it was doing...booting in your case.
You can tell how much voltage is remaining in your battery and if it is charging by checking the blinking of the battery status light.
Download the Hardware Maintenance Manual here:
http://download.lenovo.com/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/Z370&Z470&Z570/Lenovo%20Z370Z470Z570%20Hardware%20Maintenance%20Manual%20V1.0.pdf
and go to page 30 and look at item 7 under battery status for blinking light meaning.
1. Blinking amber: (500ms off/1s on)
The remaining power of the battery is less than 5% of
its capacity.
2. Blinking amber: (100ms off/3.2s on)
The battery is being charged with the remaining
power between 5% and 20% of its capacity.
3. Amber: The computer is operating on battery power with the
remaining power between 5% and 20% of its
capacity
With the AC Adapter plugged in, and giving the correct voltage, If you are getting 1. Blinking Amber (light on for 1 sec, off for 1/2 second), then the battery is not being charged. Could be AC Adapter, Battery or Battery Circuit on motherboard. If the light is solid on 3. Amber, then the battery is not charging, and is draining.
Also make sure the power socket on the laptop is not loose or damaged. If it is, then it will need to be replaced.
I hope this gets you in the right direction.
Apr 25, 2014 | Lenovo IdeaPad Z570 Notebook
Low battery
The manual says:
The camera turns off immediately even when battery power is full.
The remaining battery power is low even if new batteries are inserted.
•The remaining battery power may not be displayed accurately, and the camera may suddenly stop working, when the type of battery and the settings on [BATTERY TYPE] are not identical. However this is not a malfunction. Depending on the battery
brand and the operating temperature, or if exhausted batteries are used, the remaining battery power may not be displayed accurately.
and:
Use sufficiently charged batteries when using Ni-MH batteries.
You also should set the correct battery type in the setup menu. So put in alkaline / NiMH or oxyride. According to what you are using.
Before you panic, buy a set of alkaline batteries, to make sure your camera is ok. Perhaps you are using rechagable batteries who are not ok anymore.
Nov 09, 2013 | Panasonic Lumix DMC-LZ7 Digital Camera
Why do the ac led remain lit when its unplugged and only the battery is in?
Use this small secret. Disconnect the power adapter from laptop+ battery too.
2) Press the power button for 60 seconds EXACTLY. with the adapter+battery disconnected from the battery.
3) The idea is to eliminate de ESD from power supply, that impede to laptop to work o.k from starting.
Try again.
Hoowever if the problem remain, problem can be there in the power supply inside from laptop. You must open and repair or call some tech computer. for fix it.
God bless you
Mar 05, 2013 | Toshiba Satellite Computers & Internet
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
Total battery power remaining: Unknown
Well you can try a system restore.
1.) start
2.) programs / accessories / system tools
3.) system restore
follow the on screen instructions too restore the computer to a few days before it started having problems.
Chances are that the battery is shot if system restore fails.
Mar 01, 2010 | Acer TravelMate 5720-6635 Notebook
Laptop battery meter reading unknown remaining
your battery is spoilt. but first try recalibrating it at system start up (if your laptop has that option) otherwise, you have to buy another battery.
Regards
Feb 24, 2010 | Computers & Internet
Remaining Batter Power is not displayed in Power Meter
Go to control panel and click on Power Options.
Click on advanced and check if icon display on task bar is enabled.
Click OK
Also in the power meter icon click on the battery icon s if you are using 2 batteries
Dec 08, 2009 | HP Compaq nx5000 Notebook
Does not switch to AC power
check the power cable...if it does not detect the AC voltage from the wall it will remain in the DC mode sourcing from its battery
Aug 11, 2009 | Powerware Best Power Fortress UPS System
Ipod not charging
it may be possible that your itunes does not recognize your player becauseno power remains in the battery. try charging your player loner or if it doesn't work that way, have the battery changed
Mar 10, 2009 | Apple iPod nano
Cameras Logo
174 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
