Question about Asus Systems Asus X501A Notebook
Why does the space bar only have a centre touch point
    Habit-Forming:
  • Asus Systems Expert
  • 89 Answers
The reason for this happening is that the metal bar under your spacebar is not properly attached. It's time consuming to properly fix it, but it's an easy fix at that.
All you need to do is remove your spacebar and metal bar (shaped somewhat like a tall C, if held sideways). On the bottom of the spacebar will be approximately 2-3 small clips in which the metal bar will snap into. Once snapped into place, you will want to look at the area where the spacebar goes. There should be two small clips at each end. With the metal bar clipped into the spacebar, you want to place the "ends" of the metal bar under the clips on the keyboard and very carefully place the spacebar into the hole on the keyboard and snap it into place. Now test it out and it should work fine. If not, it's likely that the metal bar came out from under the keyboard clips. The annoying part is snapping the spacebar into place without having the metal piece come out from under those clips, so you may need to perform this task a few times.
Here's an example image...
Why does the space bar only have a centre touch po - 18971690-l5kwqkgrhcxrvei1oqtkoiub-2-0.jpg
Posted on Jan 13, 2015
I was recently given my mother-in- law's Singer touch-tronic 2000 sewing machine. The needle bar does not work. What could the problem be. Please help me. Thank you
check with a singer service centre but some singers have a belt drive inside the case that works the needle bar mechanism
they are known to break
it is in side at the right hand end just behind the outside pulley
Jul 25, 2015 | Singer Sewing Machines
SPACE BAR NOT AS TOUCH SENSITIVES BEFORE
That is usually caused from something getting stuck under it. Get a can of compressed air and use it with the tube that attaches to the can to blow out the debris under the space bar.
Mar 13, 2015 | Computers & Internet
(Remington Streamliner) the space bar automatically tabs instead of moving one space forward. How do I fix this?
This can mean that the spacebar is not being tapped hard enough, the spacebar is sticky, the escapement is sticky, or the spacebar linkage needs adjusted. If the letters do not cause this, then the escapement being sticky is less of a concern. Sometimes the touch on the spacebar is right on the point where the escapement mechanism just barely escapes and doesn't lock in. First try tapping the spacebar more firmly to see if this helps.
Aug 14, 2013 | Office Equipment & Supplies
RESET MARGINS
Move carrier to the point you want it by using the back space or space bar touch the mar L or mar R as needed
Dec 09, 2010 | Smith Corona Wordsmith 200 Typewriter
My spacebar key is no longer working properly. I have an acer aspire laptop 5735Z . I deliberately pulled the key off to clean underneath and then just clicked it back on, thinking it would work normally....
There is usually a metal piece under the space bar, if it isn't seated properly the space bar will teeter. Try to remove again and see if they metal bracket is seated correctly.
Oct 18, 2017 | Acer NSK8458AN Keyboard
Windows vista states insufficient space on Maxtor One Touch drive
You could check that the backup software settings are pointing to the correct drive. (I've made this mistake before).
Nov 03, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
The contact on the space bar came apart
This is usually an easy fix just observe the points where the space bar inserts and line them up and press firmly It should go back in place easily and be springy like before
Jul 30, 2009 | Computers & Internet
What is the function of the button below the space bar
Thats touchpad locker - when you using keyboard with both hands, you can lock touchpad from accidental touching and moving cursor.
Mar 12, 2009 | HP Compaq Presario CQ70120US Notebook PC
Fan noise and space bar issue
Heyo, the fan needs to be cleaned. Your environment air may be the culprit...if that is the case, I am sure the space bar is doing that for the same reason. If you can afford to take it to the shop to have the shell taken off and cleaned properly, I would do it.
Jan 03, 2008 | HP Pavilion dv9000z Notebook
Asus Systems Asus X501A Notebook Logo
117 people viewed this question
Top Asus Systems Computers & Internet Experts
Gregg Errera
Gregg Errera
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you an Asus Systems Computer and Internet Expert? Answer questions, earn points and help others
