Samsung la40a450c1d I am havind issues with light settings on my TV. TV starts with darker picture and then comes brighter. Other issue is that I get white edge (very briefly) around the outline of objects when the move quickly on the screen.
    Top Expert:
  • Televison & ... Master
  • 75,591 Answers
It sounds that the backlight to this TV have some fault. Might be of weak CCFL lamps. Contact any service technician.
Posted on Jul 22, 2013
  • 28 Answers
SOURCE: Bright spot on screen.
I'd say that's just the way they're made. The background light for the screen just doesn't illuminate evenly. If it's noticeable enough I'd try to get it replaced under warranty. This can also happen when the screen is pushed and it gets damaged, but if it's happened twice it's probably just the way they're manufactured.
Posted on Nov 09, 2007
SOURCE: picture edges blurry
There is a setting labeled cropping... turn it on.
Posted on Nov 24, 2007
  • 3 Answers
SOURCE: samsung series 5 530 46" LCD
RE: Product Defect
If Its new enough to return without store rejection or if you still have a valid warranty --take it back! --
Posted on Aug 18, 2008
  • 73 Answers
SOURCE: My brand new 40
This is a characteristic of the dynamic backlight used on this set.Turn off the dynamic contrast in the customer menu this should solve your problem.
Posted on Oct 15, 2009
SOURCE: Toshiba 40" LCD TV has bands each side where picture is brighter
Same Problem Here on different Toshiba Model. Did you get it fixed?
Posted on Oct 19, 2009
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
I noticed that my TV Sony Wega LCD Projection TV picture is darker than before. I tried to set brightness to very high, but still seems to be darker
hello, if you go in to the menu and click on to picture setting half way down the screen is the word reset click on this it should make it brighter hope it works
regards
shaun
Dec 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV will turn off then turn back on by itself the input shows up at the top when it comes back on. The start up sound does not play when the picture restores. Has happened when watching TV (HDMI) and play...
The first thing to do is disconnect ANYthing that is connected via HDMI and then use the component, composite or s-video inputs and see what happens. If it works ok then most likely what ever is connected to your TV via HDMI is causing the issue (it does happen). The second thing if that doesn't solve the issue is replace the lamp if its getting really dar and has never been done before. If the emmisions of the lamp are low (darker picture) the set thinks the lamp is not on and will force a restart..Please take a moment to rate my answer...Thanks
May 18, 2010 | Samsung HLP5067W Television
Screen getting dark
If you have never changed the lamp this is more than likely the issue, as the tv ages the lamp looses brightness. Most lamps are rated for 3000-5000 hrs of use. Replace the lamp assembly part # UX21514 and you will notice a much brighter picture. You do not mention if the tv plays the right colors on the entire screen. These have had light engine issues.
Good luck with it
JOTVGUY
Apr 07, 2009 | Hitachi 50VX915 Rear Projection Television
Picture pulses
replace the flote.
any repairman will know wat this is.
part cost is from $56 to $93.
check around
partsstore dot com keeps a good parts stock for tompson or rca.
hope this helps
regards,
daniel.
Jan 13, 2009 | RCA P60921 60" Rear Projection Television
TV not staying on
I called a tech and it was a convergence issue. It cost $375 to fix.
Jul 05, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Picture getting darker
The tv has a room light sensor,
shine a bright light at it , does picture get brighter?
other wise when it is cool open the bulb door , is it coated or blackened, Don't touch bulb at all.
and a heavy covering of dust on internal mirrors will cause the same effect.
you will need help to clean it.
Jan 26, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Strange picture issues
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Mar 18, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
