Question about Lenovo Computers & Internet
Consider replacing your battery
How to solve the problem in lenovo z560 laptop the battery shows "consider replacing your battery"
4 Suggested Answers
RobRocks
  • 68 Answers
SOURCE: In my lenovo z560 laptop
Hi- Lets see if I understand you correctly. You currently have Windows 7 installed on your computer and want ot install Windows XP correct?. It can be done but you need too do a few thingd before you insatll Windows XP.
First you need to create a partition for the Windows XP installation. (A partition is basicly spliting up your harddrive into 2 disk).
Next after you haver created your partition you can then start you XP installation. Remember you must install Windows XP into the newly created partition.
Then after Windows Xp is installed your need to repair the boot manager from the Windows 7 disc.
The reason why is XP will install it's own (older) version, and XP's boot manager can not boot to win 7. Repairing using the Win 7 disc will re-install Win7's boot manager, which can start XP.
I hope this helps
Posted on Dec 30, 2010
Matrix12
  • 370 Answers
SOURCE: My lenovo z560 laptop's key
Welcome to FixYa!
it seems that you are having problem with the keyboard on the laptop, unfortunately, even if you send it to the repair center of Lenovo, they will replaced the whole keyboard since there's no particular part number for just one key on the keyboard so they usually replaced the whole of it.
Hope this will help. Thank you for using FixYa!
Posted on Jul 04, 2011
Geekman
  • 32281 Answers
SOURCE: lenovo z560 cpu overheating problem solved
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Posted on Jul 24, 2012
IdeaPad Z560 79% available "Plugged in but not charging" message
Bad battery? Is the battery a replacement? Test cord/charger.
Nov 26, 2012 | Lenovo IdeaPad Z560 Notebook
Nvidia driver not intstal in ideapad Z560 in Windows XP
Try to download again. delete corrupt file. Perhaps it was a "Hiccup" By the way you have a Lenovo IdeaPad Z560 didn't that come with Windows 7 64bit? Did you downgrade to Win XP SP2?
Nov 04, 2012 | Lenovo IdeaPad Z560 Notebook
Lenovo z560 cpu overheating problem solved
Jul 24, 2012 | Lenovo IdeaPad Z560 Laptop
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
May 14, 2012 | Lenovo IdeaPad Z560 Notebook
Every time when i try to boot, it asks for press f12
Your CEMOS Battery of your laptop has been damaged.. consider replacing it. Hope your problem will be solved then.
For any further help contact me on 09613522133 Biswajeet Choudhury thank you.
Aug 29, 2011 | Lenovo IdeaPad Z560 Notebook
I purchased a lenovo z560 laptop last month, but its F12 key's lock is broken, is there any way to overcome this problem. I am very confused please suggest any help .....
If you are interested you can use external mini usb keyboard.
If possible call to lenovo call center and ask for replacement of key board.
Jul 04, 2011 | Lenovo IdeaPad Z560 Notebook
If the battery is fully charged when i plug the charger stopped charging or not in Lenovo z560 ?
Welcome to FixYa
When the battery is fully charged and you still have the ac adapter plugged in then the battery would no longer be charged. The computer would then be running on ac adapter power.
hope this helps
Jun 04, 2011 | Lenovo IdeaPad Z560 Notebook
How to get a product id of lenovo ideapad Z560
Hi there Sadi,
I have used this type of laptop before, the product ID is located under the batter of the laptop.
To find it you must remove the laptop battery and look at the sticker that has the ID # on it.
Mar 05, 2011 | Lenovo IdeaPad Z560(0914-3NU) NoteBook...
The laptop lenovo z560 does not switch on. With battery it shows 2 short flashes of battery charge idicator, an one long (about 10 sec) and than nothing is happening. Withou battery nothing happens after...
Hi smialkovskyi,
With this specific concern that you do have, unable to turn on your Lenovo Z560, there 3 components that need to be checked. Your battery, the AC adapter (charger) and as well as the DC In port.
1.Based on what you have said, with the battery alone you have noticed that it's led indicator will show however still can't turn on system. Battery seems to be in good condition however no enough charge to turn on the system.
2. For your AC adapter, when you're using it without the battery nothing happens. To check if this is defective try using another AC adapter that is compatible to your unit. If your computer turned on using another AC adapter then your charger needs replacement. (You may also try using your charger to other unit where it is compatible, just to test).
3. However, if after doing the previous instruction and still system won't turn on then it could be the DC In port which is defective. This port is built in to *********** board.
After doing all these you need to contact Lenovo. They might be replacing your charger or *********** board if system is under warranty.
Hope this helps.
Thank you for using Fixya.
Jan 28, 2011 | Lifetime Lenovo/IBM IdeaPad Z560...
Computers & Internet Logo
83 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
