Question about Electrical Supplies
Overload indicator light is on with nothing plugged in, will this shut the engine off
2 Suggested Answers
  • 1632 Answers
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Posted on May 22, 2009
Yamaha 2400IS Generator goes to overload when ie: 240 volt plugged in, or 700 watt angle grinder plugged in.
No idea but somebody else will probably come along with a better idea then mine, seems a lot of these generators have this thing installed on them (Has $25 hard start kit). Not sure what it does or how it works. Strangely enough you said you use it for 240 volt. Looked at the picture and didn't see a 240 volt connection.
If you are using the what look like the 120 volt circuits you can't over load the unit. Maximum current draw will cause it to go into protection mode and shut down the power load. The following is an exert from the owners manual which I got from Yamaha's site. Link at the end of this post.
Hope this helps
16
q
760-029
AE00788
The overload indicator light
comes on when an over-
load of a connected electrical device is detected, the
inverter control unit overheats, or the AC output voltage
rises. The electronic breaker will then activate, stopping
power generation in order to protect the generator and
any connected electric devices. The AC pilot light
(green) will go off and the overload indicator light (red)
will stay on, but the engine will not stop running.
When the overload indicator light comes on and power
generation stops, proceed as follows:
1. Turn off any connected electric devices and stop
the engine.
2. Reduce the total wattage of connected electric
devices within the application range.
3. Check for blockages in the cooling air inlet and
around the control unit. If any blockages are found,
remove.
4. After checking, restart the engine.
http://www.yamahamotorsports.com/assets/service/manuals/0/LIT-19626-01-23_1423.pdf
Jun 06, 2016 | Yamaha EF2400iS Portable Generator
Overload error light is lit up, but nothing is plugged in.
would you tell me what is the model number of the UPS
May 31, 2015 | Computers & Internet
Overload indicator light stays red & continuous tone ups 1100
Take the battery out and see if it does the same thing when you turn it on.
Feb 06, 2013 | APC Back-UPS Pro 1100 (BP1100) UPS System
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
I have a Tevion 7.1 amplifier (AVR 2006). Protect overload flashes up and then shuts down. I have only had limited use since I had the unit from new (a few days). Last time using it someone pluged an...
The protect indication is due to a overload on the power amplifier unit. So you need to check the speakers to see that they are not shorted. remove all the speaker lines and switch on.
if there is a processor reset, power off the set and switch on while holding the selector/standy by switch. if not there is damage in the output within the amplifier.
Apr 26, 2011 | Audio Players & Recorders
I just purchased a used Denon AVR-3200 and have nothing hooked up yet but plugged it in on my kitchen counter and upon turning the unit on, noticed the error overload button was lit up but the unit did not...
Hi
I've had an AVR 3200 for about 10 years - occasionally (maybe once every 6 months), the error overload button comes on... for no real reason than i can detect (ghosts in the machine, maybe)... rebooting has always fixed it for me.
Aug 21, 2010 | Denon AVR-3200 Receiver
Shut off and won't come back. It's like it is dead.
follow this procedure:
1. unplug the ac adapter and keep it unplugged.
2. Remove the battery and keep the battery unplugged.
3. Hold the power button down for 15-20 seconds(Nothing will appear on the display and none of the lights will light up)
4. Release the power button and plug in the ac adapter ONLY. (A power indicator light should be lit on the ac adapter when it is plugged in)
5. Normally power on the notebook.
6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
7. Plug the ac adapter back into the system, the battery charging indicator light will light up. If the battery indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Char S.
May 27, 2009 | Acer Extensa 5420-5687 Notebook
Honda eu 6500 gen overload indicator light will not shut off
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Reset Button
your testing the no fault short or motor overload feature. the red light indicates you have power. no light no power.
Apr 02, 2008 | Karcher 2500 PSI Pressure Washer
E40 error code
The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Dec 16, 2007 | Zanussi ZWF1440 Front Load Washer
Electrical Supplies Logo
156 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
