Question about Music
How to hook up a recorder to a soundtech s824 mixer
We are trying to record some of our church services and we have a soundtech s824 mixer and we can't seem to get the computer hooked up right to record.
  • 1138 Answers
SOURCE: how to hook up alesis air fx to 16channel makie mixer what jack it goes into
Go to http://www.zzounds.com/item-ALEAIRFX.Under the picture you will see About This Product. Click on DOCs and you can download the manuals for it. Read the manual carefully and it is explained very well. Use your mixer manual to get the best set up. I would recommend using it in an FX loop that lets you mix the individual channels FX into the output you have hooked up to your computer.
Posted on May 19, 2009
rexark
  • 55 Answers
SOURCE: hook up audio ut to audio in from mixer to computer
You just need a USB audio interface ... the outputs from your mixer are analog, which will plug into the right/left inputs on the audio interface ... and the audio interface connects to the computer via USB ... this is a very common way to do it ...
There are a lot of devices out there ... I'm using a Tapco Link.USB audio interface ... not too expensive ... you don't need anything fancy ...
Once you get the USB audio interface (by the way, if you are using a Mac you probably do not need to install any software for it) then you want to make sure your audio inputs are set to use it ... there are two ways to do this .. first way is right in the Cooledit software, if there is a place to tell the software what the input audio device is ... if this is not possible then change your systems general audio settings to select the USB audio interface for sound input.
That's it!
For audio expertise with conference recording and presentation and help with PA system problems, visit www.rexark.com
Posted on Mar 06, 2010
  • 5603 Answers
SOURCE: How do i hook up my new behringer pmp 5000 mixer
Passive loudspeakers are connected to the two "Speakon" connectors on the back of the unit. BUY GOOD cables for your speakers!!!! Whatever you do don't have a speaker line come loose while driving audio out !!! You will arc- out the rear-most power amp... I know, I repaired two of these now with the problem.
Connect the recording device to either the "tape OUT" RCA jacks or either of the pairs of MAIN out TRS jacks.
Set the slide switch for the MAIN L/MAIN R (upper position) leave this in this position unless you understand what the other positions are for to avoid damage. You will NOT need the other positions.
Further: Power ALL interconnect devices from the SAME receptacle source to avoid ground loops and possible damage.
YOUR passive speakers should be rated at least 300 Watts RMS continuos power handling or 600 Watts peaks.
Drive consumer stereo speakers with this and you will smoke the speakers and MAYBE blow the amp. This is a powerful amplifier and if you don't have at least 15 inch speakers you MUST really hold down the volume lest you blow the speakers.
Above all read the manual... yes, it is a bit hard to understand...
If you have a problem you can contact me by email for a bit of help. I have wo of these I have been using at venues now.
Posted on Apr 24, 2010
Testimonial: "Thank you fredy2. im very grateful. Wish i had know about this site before i purchased some of my gear. I will follow these recommendations. THANKS,"
  • 5603 Answers
SOURCE: I have a mackie 24 channel mixer , I am trying to
Decide if you want to use the AUX's or the SUB's for your monitors. (usually use the AUX).
Connect TRS cables from the appropriate AUX sends to thee amplifiers you use for your monitors or your powered monitors whichever you have.
Adjust the level using the AUX level controls for each channel to set your minitor mix.
Normally use the PreFader AUX's so monitor levels are set independent of the slide fader positions.
Here is a big hint for you: Search YouTube.com for "Soundboard" or "Soundboard setup". There are good videos there that might be different than your particular board, but there is enough commonality that you will soon be an expert!
Posted on Sep 21, 2010
  • 5603 Answers
SOURCE: i have a behringer xenyx
Yep ! First thing is to eliminate any processing resource "hogs" that **** respources and can cause buffer overruns. Eliminate Antivirus, antispyware, and network communication and wireless network programs running in the background while recording.
Next make sure that ALL equipment is powered from the same receptacle or power source. In your case that should be the mixer and the PC.
Next remember that the condenser mic picks up everything... I have 5 of those mics and seemingly noise free environments turn out to have little things that generate fast rising pulses that you don't notice till they are recorded.
Lastly, the air here is very dry and plain old static electricity is rampart... Lady shuffling her feet was sending pulses through the mic cable at our church. They are NOT audible until they get into the sound system as clicks.
I have found that trying to record directely to a USB stick often has ooverruns and clicks... also burning a CD from stick to the CD results in noise due to buffer underuns. Burn from Hard drive to CD and make sure all the other hog programs are shut off.
Posted on Jan 04, 2011
Know how to hook uo thr cables to record from my mixer amp
We would need to know what make/model mixer and recording device you are trying to connect.
Jan 12, 2017 | AMP Music
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
Why does my mixer freeze up?
Mixer brand and model? Are you recording on a DAW? Give us more info, so we can help you. If you're recording on a DAW, try to uninstall the drivers and install again, that should work...
Nov 24, 2014 | Music
I am trying to connect a computer to a peavey src 4026 to record sermons
Why not un-complicate the circuits by eliminating the soundboard first?
May 11, 2017 | Peavey Music
The power supply blew and I need the schematic for the power supply.
Soundcraft USA
8500 Balboa Boulevard
Northridge
CA 91329
TEL: 818.920.3212
FAX: 818.920.3208
EMAIL: soundcraft-usa@harman.com
WEB: http://www.soundcraft.com
Sound Technology plc
Letchworth Point
Letchworth
SG6 1ND
TEL: 01462 480000
EMAIL: info@soundtech.co.uk
WEB: http://www.soundtech.co.uk
Mr Jorg ter Veer
Audio Pro Elektroakustik GmbH
Pfaffenstrasse 25
74078 Heilbronn
TEL: +49 (7131) 2636 400
FAX: +49 (7131) 2636 430
EMAIL: info@audiopro.de
WEB: http://www.audiopro.de
Soundcraft Homepage
Nov 04, 2011 | Soundcraft Epm6 6-channel Multi-format...
I can't hear sound from my PC when I'm using the mixer. I plugged it in with the USB to the computer and tried to record using Cubase 4 LE. I seem to get sound in, but i can't hear any sounds from the...
In the "Sounds and Devices" of teh control panel under the Voice and also recording tabs amke sure the 2442 is selected instead of teh computer internal audiop system.
Feb 18, 2011 | Behringer XENYX 2442FX Mixer
I have a behringer xenyx 1204usb mixer with a mxl 990 mic and i have problems with static. thats all i have hooked to the mixer so i dont think its a conflict. i have tried recording in audition, pro...
Jan 04, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I was trying to hook up our 1604 vlz3 at our church and was wondering how the best way to do this?
Without knowing the resources you are connecting I cannot give you a schematic but will give this GENERAL advice:
1. Use BALANCED lines to connect from the mixer to your amps, preferably XLR connections.
2. Service the power to the amps and the mixer from the SAME place even if it means stringing a power cable alongside you audio cable snake.
Jun 12, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Music Logo
54 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
