Error code 2.01:10 hp designjet t610 plotter.
Joed911
  • 4338 Answers
SOURCE: error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 27, 2008
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
seeker5211
  • 1089 Answers
SOURCE: My plotter is saying that
The printer is having a problem finding the Scan-axis encoder reading.
Start by upgrading the firmware. Go to www.hp.com. Go to Support and Drivers.
Enter your printer model, select your operating system, select firmware.
Follow the directions.
If that doesn't fix the problem, clean the encoder strip( the flat metal strip that runs the length of the printer).
If the problem persists, someone trained on DesignJets is going to have to look at it.
Hopefully, the firmware will fix the problem.
Posted on Mar 24, 2011
seeker5211
  • 1089 Answers
SOURCE: Hi, In the office we
It is a PPS system failure(Pen to Paper Space).
Turn power off and pull the plug from the wall outlet.
Reconnect and power on.
In the Diagnostics perform the Scan Axis PRS diag test.
If it still fails a tech is going to have to look at it.
Sorry, but this may need parts replaced. A print mech board or the PPS solenoid.
Posted on Mar 26, 2011
ahmad_archit
SOURCE: I need help in loading
my plotter, HP Designjet T610 has a problem I have problems printing large files.
When I send a large file, it appears "Out of memory" in the front panel of the plotter. People of HP recommended me to select the option "send as bitmap" but it doesn`t work. If I activate that option, it takes too much time to print a file. For example, aa autocad file having gradient on it, or cad drawing with picture and some layer on it...
the result is that..some are printing and some missing
Posted on Mar 18, 2013
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
I have hp t610 plotter and it incurred paper jam
Check the carriage belt for wear. Is there an error code?
Aug 19, 2013 | HP Designjet T610 InkJet Printer
Trying to connect a hp designjet t610 to a network using a usb
You cant from a network on a USB connection. USB connections are for "local" printers. "add" the Designjet T610 printer to your other PC under "printers and devices" tab. Good luck !
Feb 19, 2013 | HP Designjet T610 InkJet Printer
Paper loaded incorrectly.remove paper in HP plotter T610.
T610 with "paper loaded incorrectly" error. Finally removed the paper roll completely and still had error. Opened top, but no signs of paper. I walked behind plotter and on the left , in the paper path ,I found the paper sensor using a flashlight. I got on my back and reached underneath to remove the plastic cover securing the paper sensor and the sensor itself. The sensor was dirty. Blew it off, reattached it and the error disappeared.
Jul 21, 2011 | HP Designjet T610 InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
Jul 31, 2009 | HP Office Equipment & Supplies
Error code 22.1:10 on HP Designjet T610
800-HP invent
or
Thanks, Joe
Nov 18, 2008 | HP LaserJet 4 plus Printer
101 people viewed this question
k24674
jasbo
jasbo
