Question about Emerson 42" Class Lcd 1080P 60Hz Hdtv
Red flashing light on a emerson tv it won't turn on
There is a red flashing light next to the power light on the tv and the tv will not turn on it just keeps flashing i even unpluged it fon hour and all i get when i plug it back up is a red flashing light
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
dsacco86
  • 1077 Answers
SOURCE: The tv will not turn on with either the remote or
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TV made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 13, 2009
  • 1684 Answers
SOURCE: emerson lc32oem8 32
The flashing power light indicates a failure in the power supply board of your tv. We should be able to repair the board for our standard rate of $45 plus return shipping. If you are interested in setting up a repair please use the following link to our web site: http://www.ccl-la.com/blog/index.php/service-request-form/ Our normal repair turn around time is 2-3 days.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Mar 08, 2010
Testimonial: "thanks!"
SOURCE: my emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Posted on Dec 20, 2010
SOURCE: my flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Posted on Dec 26, 2010
Emerson lc320emx trouble turning on
You probably have an internal power supply problem
Mar 04, 2013 | Emerson LC320EM9 32 in. LCD HDTV
My emerson lc320em1f tv won't turn on.
Calm down, Calm down! Your power supply board is at fault. On the power supply, you have a bad diode. Location of this diode is D639. Replace it with an NTE 5087A. Thanks for asking, Matt of Martins TV Repair.
Jan 27, 2013 | Televison & Video
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
Emerson tv....won't turn on...stand by light won't go off
Not making it on or out of standby---first place to look is the power supply for signs of damage or puffed up filter caps there.
Dec 10, 2012 | Emerson SLC195EM8 LCD TV
It won't turn on, the red light flashes
That means that its no good and needs to be replaced
Aug 02, 2012 | Emerson LC320EM8 32 in. LCD TV
I have a Emerson 32inch LHD32K20US and it won't
ry changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Televison & Video
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
My flatscreen emerson tv will not turn back on.
Mar 30, 2009 | Emerson LC320EM8 32 in. LCD TV
My emerson tv standby light is on the power light flashes twice
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Emerson 42" Class Lcd 1080P 60Hz Hdtv Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
