Question about Canon N 1000 InkJet Printer
E850 0030 Service Call E850-0030 Ink tank cover does not open. Coming off of unlock shaft Tank cover sensor
thumu
  • 69 Answers
SOURCE: My prixma IP 1000 has message "Waste Ink Tank full, contact Service Engg."
Please try below steps on your Printer and let me know the result. I hope this should work.
Steps are:
 Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
This should work. please let me know the result.
Bye.
Posted on Oct 18, 2007
SOURCE: MP500 ink tank cannot be recognized error U043
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Posted on Sep 04, 2008
SOURCE: Error messages: U150 + Ink tank errors have occured
An on-line problem solver answered this question for me as follows, and it worked beautifully. I had previously tried just removing the ink cartridges, and then re inserting them, but that did not work.
"This is a somewhat common problem with the metal contacts that connect to the ink cartridge. Sometimes it can be fixed by cleaning the contacts, but other times it requires getting a new ink holder from Canon customer service.
To clean the contacts, you'll need a Q-tip and some isopropyl alcohol (it's important that it is isopropyl and not another kind of alcohol). Pull out the ink cartridges and clean the contacts on each one with the Q-tip dipped in alcohol. In particular, you want to make sure there are no fingerprints on the contacts. Then, turn off your printer and do the same with the contacts in the ink holder in the printer. Once the alcohol has dried on both sides, reinstall the cartridges and give it a try.
If this doesn't work, I recommend calling Canon tech support, so they can send you a replacement part."
According to Canon's instruction manual, you must complete the cleaning in less than 10 minutes. It took me about five. I did exactly the tech suggested, and after turning everything off and waiting a minute or so, I restarted everything, and the problem was solved.
You must be careful though, because if you leave a Canon Pi6600 cartridge out of the printer for more than 10 minutes, not only will the cartridge tray move back to the "off" position (out of reach), but the ink cartridges nossles will dry out and possibly not work. Also, do not "squeeze" the ink cartridges or you will get ink on yourself.
Posted on Jan 10, 2009
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Posted on Sep 12, 2009
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Posted on Nov 30, 2009
Canon mp830 service error 5c310 alarm light keeps
http://damnprinter.com/226/canon-service-call-errors.html
http://www.fixyourownprinter.com/forums/inkjet/26091
You need to clean your waste ink i think. For troubleshooting purposes, please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
May 17, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How do you remove the ink cartridges from the
To service the ink tanks:
Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
i_note_us.gif Note
If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2 Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3 Remove the ink tank whose lamp is flashing fast.
(1) Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Important
bullet_s.gif Handle ink tanks carefully to avoid staining clothing or the surrounding area.
bullet_s.gif Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
i_note_us.gif Note
Be sure to replace ink tanks one by one when replacing more than one ink tank.
4 Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
(1) Unpack the new ink tank and completely pull off the orange tape. Then, remove the film.
(2) Remove the orange protective cap from the bottom of the ink tank and discard it.
Important
bullet_s.gif Be sure to remove the clear film from the ink tank in the exact order shown in step 4-(1), as failure to follow this step may cause the ink to leak and stain your clothes and hands.
bullet_s.gif Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
bullet_s.gif Do not re-attach the protective cap once you have removed it.
bullet_s.gif Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
bullet_s.gif Ink on the removed protective cap may stain your clothes and hands.
bullet_s.gif Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5 Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the push_3.gif mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important
Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6 Close the Inner Cover.
i_note_us.gif Note
Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7 Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
i_note_us.gif Note
bullet_s.gif The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
bullet_s.gif To maintain optimal print quality, use an ink tank within six months of first use.
bullet_s.gif Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
bullet_s.gif Color ink consumption may occur even when black-and-white or gray scale printing is specified.
Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
bullet_s.gif When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Apr 03, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
U150 The following ink tank cannot be recognised (black 8)
If the following error occurs "The following ink tank cannot be recognized" error code U043, U140, U150
Action 1 : The ink tank is not installed in the ink tank. Install the ink tank. Refer to "Replacing an ink Tank" below.
Action 2 : The ink tank is not compatible with the machine. (The lamp on the ink tank is off.) Install an appropriate ink tank.
Refer to "Replacing an ink tank" below.
Replacing Ink Tanks.
Action 3 : An ink tank error has occurred (The lamp on the ink tank is off).
Replace the ink tank.
Replacing an ink tank :
Replace the ink tank using the following steps :
1) Open the Paper Output Tray.
Put your finger in the rounded indent of the Paper Output tray and open it gently.
2) Make sure that the machine is turned on, and lift the Scanning Unit (Printer Cover) until it stops.
Caution : * Do not hold the LCD or the Operation Panel.
* Do not hold the Print Head Holder to stop or move it.
Important : If the Scanning Unit (Printer Cover) is left open for more than 10 minutes, the Printer Head Holder moves to the right side. Close and reopen the Scanning Unit (Printer Cover) to return the holder to the center.
3) OPen the Inner Cover.
Caution : Do not touch the metallic parts inside the machine.
4) Remove the ink tank whose lamp is flashing fast.
Important : * Handle ink tanks carefully to avoid staining clothing or surrounding area.
* Discard empty ink tanks according to the local laws and regualtions regarding disposal of consumables.
Note : * Do not remove more than one ink tank at a time. Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare the replacement tank.
a) Remove the new ink tank from its packaging.
b) Pull the orange tape to peel off the protective film.
c) Remove the film completely.
Important : Make sure that the protective film does not remain in the air hole. If the air hole is blocked with the remaining film, ink may leak out or may not eject properly.
d) Remove the orange protective cap from the bottom of the ink tank.
Discard the cap once it is removed.
Important : * Do not touch the electrical contacts on the ink tank. Doing so can cause the machine to malfunction or become unable to print.
* Be sure to remove the clear film from the ink tank in the exact order, as failure to follow this step may cause the ink to leak and stain your clothes and hands.
* Do not squeeze the side of the ink tanks as this may cause the ink to leak out and stain your clothes and hands.
* Do not reattach the protective cap once you have removed it, Discard it according to the local laws and regulations regarding the disposal of consumables.
* Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
6) Install the ink tank.
a) Insert the front end of the ink tank into the Print Head. Make sure the position of the tank matched the label.
b) Press on the "press" mark on the ink tank until the ink tank snaps firmly into place.
c) Make sure that the ink lamp lights up red.
Important : Install all the ink tanks to print. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note : Make sure that the Inner Cover is closed. Printing will not start with the Inner Cover open since paper cannot be fed properly.
8) Gently close the Scanning Unit (Printer Cover).
Caution : * Be sure to hold the Scanning Unit (Printer Cover) firmly using both hands, and be careful not to get your fingers caught.
* Do not hold the LCD or the OPeration Panel.
Note : * When you start printing after replacing the ink tank. Print Head Cleaning is performed automatically. Do not start another operation until the machine has stopped making operating noises.
Hope this helps.
PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon MP610 Photo All-In-One Printer
Replaced the magenta cartrage. arror check Ink
The Error "Check INK U140"
Causes : Possible causes are as follows :
* The ink tank may not be installed properly (The lamp on the ink tank is off).
Install the appropriate ink tank.
* The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
Install the appropriate Ink tank.
The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Replacing Tanks
1) Ensure that the machine is on.
2) Raise the Scanning Unit (Printer Cover) until it stops.
The Paper Output tray will open automatically and the Print Holder moves to the center.
Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
* Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare a replacement tank.
a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
b) Remove the orange protective cap from the bottom of the ink tank and discard it.
6) Install the ink .
a) Install the ink tank into the Print Head.
b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
c) Ensure that the ink tank clicks into place and then its lamp lights red.
Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
Hope this help. PLease rate my response.
Thanks
have a good day.
Nov 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
How do load the ink for iP6310D printer
Hi there Malatesta -
I haven't specifically changed ink on your specific model but have on another Canon printer and suspect that the process should be very similar
Here is the process that I used on the other Canon printer
Turn the printer on and open the printer cover. (The print head will move from the right to the center.)
Lift up on the Push mark on the black ink tank to unlock the ink tank from the allocated slot of the print head and lift it out.
How to Reinstall the new black ink tank
Install the new black ink tank by inserting the the new black ink tank where the old one was removed. Put the back rear edge in first. Then press down the Push mark on the front top of the black ink tank until it snaps into place with a click sound
Close the printer cover and you are done
Hope that makes sense...
Take Care,
Michael
Nov 08, 2008 | Office Equipment & Supplies
How do I remove and install new black ink cartridge in Canon K10222 printer please
How to Remove the black ink tank on the Canon K10222
Take Care,
Michael
Nov 06, 2008 | Office Equipment & Supplies
Just bought new ink for my printer; Canon MP510 it says it cannot recognize magenta....it is the correct one CLI-8m, it lights up, then I close the cover , it says processing, then it says the following...
Hi, please try reseating the print head.
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position.
If issue still present call your printer manufacturer for service.
Tirzo
Jun 12, 2008 | Office Equipment & Supplies
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Ink tank lamp lights not coming on when ink cartridges installed
Remove tape from the ink tank - MP800R / MP830 / MP530
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads. It is necessary to adjust air pressure outside and inside the tank so that ink flows properly. If ink does not come out, check to make sure that the protective film has been correctly removed.
    Caution:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press on the tab to release the ink tank (1), then remove it from its slot (2).
    Caution:
    a. Do not remove the print head from the machine.
    b. If several ink tanks need replacing, remove and replace each one individually.
  5. Check the ink tank. If the orange tape is as shown in Figure (1), it is properly removed.
  6. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  7. Insert the ink tank diagonally into the print head.
  8. Press it in firmly until it locks into place.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  9. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
  10. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Dec 26, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon N 1000 InkJet Printer Logo
24 people viewed this question
old marine
old marine
