Question about LG Flatron Ips236v-pn 23" Widescreen Led Lcd Monitor - Black
Lg flatron ips236 osd locked
Osd locked message comes up and can't shut off monitor??????
  • 556 Answers
SOURCE: Shape of LG Monitor
What are actual value for all the shape properties? it is already in owenr's manual.
Posted on Sep 26, 2007
SOURCE: FLATRON L192WS LG
hold de book buton 5 or 6 sek
Posted on Aug 26, 2008
rj_8017
  • 22 Answers
SOURCE: Message: OSD LOCKED'' when i press a button on my LG Flatron L1720
change all pressing keys..then press menu key 15 seconds for unlocked.
Posted on Jan 23, 2010
SOURCE: omi have lg flatron 1941s
i have a problem with my lcd a small area is permanently black a scratch like lines less than 4 mm X3 mm size
Posted on Oct 07, 2010
  • 452 Answers
SOURCE: My LG Flatron L1520B monitor "Locked/Unlocked"
press the power button for 1 mn and release it if still the same problem change your inverter board.
Posted on Oct 28, 2010
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
Mar 25, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
When i try to adjust the monitor controls message comes up OSD locked, how do I unlock it
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Oct 24, 2010 | Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Power button locked
Please tip and trick in my profile: http://www.fixya.com/users/budmrtn
? OSD Lock —The OSD can be enabled or disabled by
“SD Lock”displays for 10 seconds.
?If the OSD is locked, press and hold the Menu button for
?If the OSD is unlocked, press and hold the Menu button
Apr 15, 2010 | HP w1907 LCD Monitor
The button on the front has functions but when I press either the left hand side or the right hand side it just comes up with a message ''OSD Locked'' What does this mean
OSD Locked means that your On Screen Display is locked. That basically means you can't access/change the menu settings. The way to unlock the OSD varies from manufacturer to manufacturer and even monitor to monitor. Here are a couple different ways to unlock it:
1) The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
OR
2) Go to Menu and select OSD settings and change the setting for the OSD Lock. For example if it is a "+" then make it a "-" or a "On", then make it an "Off", or an "Enable" then make it a "Disable".
If neither of these work, I would contact customer support for your monitor from the manufacturer. They should be able to tell you how to turn off the OSD Lock.
Hope that helps. Good luck!
Feb 15, 2010 | Computers & Internet
OSD Main Controls Locked
Hold the "OK" button for about 20 seconds
It will initialy come up with the message "OSD Locked" and then after the 20 seconds a ne message will appear "OSD Unlocked"
Dec 20, 2008 | Philips 150S4FB 15" LCD Monitor
Help with my 190S monitor
I have Philips 19C monitor. From today, every 5 secs an attention message
"osd main controls locked and unlocked"
The AUTO(OK) bottons for 10 sec not give nothink
What i can to do with this?
Gregory
my mail - communar@agry.gov.il
Thanks
Aug 22, 2008 | Computers & Internet
Philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
Aug 10, 2008 | Philips 150S4FB 15" LCD Monitor
LG Flatron Ips236v-pn 23" Widescreen Led Lcd Monitor - Black Logo
374 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
