Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
60pp9363h 17 The of my TV is slowly fading out, the sound is ok what kind I do to fix this
Slinteriors
  • 8617 Answers
SOURCE: Philips 60PP9363H/17
Electronix.com has what you need they are called convergence IC's. About 6 bucks each. Type in your model number and the correct parts will be displayed its an easy fix for someone who can solder. You need two IC'c both stk part numbers. Takes about 2 hours to desolder the old and replace with new, then it basic adjustment for convergence
Posted on Jan 03, 2008
Slinteriors
  • 8617 Answers
SOURCE: Phillips hd projection tv/ model 60pp9363h/17
thats a common problem with all projection tvs. You will need to replace both convergence Ics and 4 resistors. You will need two STK392-120 Convergence ICs and four 6.8 ohm 1watt resistors. You can get replacement parts at the following link and they provide free instalation instructions so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Posted on Sep 01, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Philips 60pp9363h/17
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Ed
Posted on Nov 28, 2008
  • 4 Answers
SOURCE: SOUND BUT NO PICTURE
is it nothing on the screen at all? if so your projector bulb blew. they usually cost a coupole hundred bucks
Posted on Mar 07, 2009
Ecollier2012
  • 3459 Answers
SOURCE: 60pp9363h/17 tv has got convergence issues and a
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 18, 2009
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
Tv fades to black very low sound or or goes to blue & says lost siginal then goes toblank turn off set & waite a few min.& turn back on will only stay on for a few min. have to repeat.
This is not a "digital" problem that can be addressed in your setup or fixed at home. This sounds like a fading power supply. Often electronics fail slowly or partially.
You will need to consult a TV repairman.
I hope this helps!
Jun 15, 2010 | Olevia 237T 37 in. LCD TV
How do you get to the convergance menu on phillips 60pp9363h/17 tv
Here are two tips from www.TvRepairKits.com
"You must have the original remote. If so you can access the convergence screen by hitting the menu key"
Jun 04, 2009 | Philips 46PP9302 46" Rear Projection...
Mar 07, 2009 | Philips 60PP9363 60" Rear Projection...
Screen looks 3D
Solution:
Hope this helps,
Ed
Sep 09, 2008 | Philips 46PP9302 46" Rear Projection...
Picture is warping and colors are seperating giving a picture that looks like a 3D picture without the glasses
you need to replace both convergence Ics. Post the model number of your set and I will post the correct IC numbers as well as alink where you can get replacements with free instalation instructions. Respond to this same post so I will have access to your symptoms when you post the nodel number.
Jun 30, 2008 | Philips 46PP9302 46" Rear Projection...
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
