Cannon-ir2200 Copier Error code E000-0000 - Office Equipment & Supplies
  • 86 Answers
SOURCE: Error Code E000 on Cannon Imagerunner 1600 Copier
Get into service mode by pressing.....
additional functions key (*) key and then...
ID(#) key...
Scroll down to PRINTER then press OK
Scroll down to PRINTER RESET
then indicate YES(*)
If E000 through E004 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Any problems please get back to me
Thank You
Posted on Mar 24, 2008
  • 11 Answers
SOURCE: Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Posted on Oct 01, 2008
Cogz
  • 1326 Answers
SOURCE: How to read the meter on Cannon Copier
Yes, that is the correct counter of the copier. If you are doubting it, you can look at the bottom right of that display and confirm that the serial number is the same as on the back cover of the copier and also, it well tell you the model of the copier aswell. It is kind of hard to fake the meter or change it to a lower amount. To do it you need to change 3 PCB's from another copier & it is more work to bother with.
Posted on Nov 07, 2008
SOURCE: IR2200
When I pluge my Canon IR 3300 is showing me to Turn OFF and ON the Switch in the right, if the problem did not solve, so please send solution on Email - rajkumarsingh_kushwah@yahoo.com
Posted on May 11, 2009
  • 140 Answers
SOURCE: My copier Model is Cannon
it is related o your fixing unit. check it.
Posted on Apr 26, 2011
Cannon ir2200/ir3300 error code E000051-0000 HOW TO CLEAR IT
To help you troubleshoot the error and clear it, please follow the steps given below:
- Press Additional functions button.
- Press Function.
- Error (choice).
- Error code choice (wait).
- Press Reset button and (wait)
- Right power supply will turn off.
- Right power supply will turn on.
GuruAid.com
Jul 13, 2016 | Cannon Office Equipment & Supplies
Is cannon ir 2200 the shows me error E000051-0000. How can restore it
clearing error code E000051-0000 in canon IR2200
Try to reset the printer follow this stepTo reset the error
1. Additional functions (push)
2. Function (choice)
3. Error (choice)
4. Error code choice (wait)
5. Reset (push)
6. Right power supply off
7. Right power supply on
Oct 24, 2015 | Cannon Office Equipment & Supplies
Ir2200. E00000-0000 what solution
This normally implies a functional issue with the machine. Try an error reset first in case the unit was turned on\off or lost power recently: To reset the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR. If that doesn't work you will need to test some components - are you a repair tech or have electronic experience if not you might want to contact a service center to avoid hurting the copier or yourself. If you do have experience take a look at page 6-10P http://diagramasde.com/diagramas/otros2/IR2200_2.PDF and Error Codes Canon iR2200 Warning!
If you are not familiar with electronics, do not attempt to repair!
There is a risk of fatal electrical shock! Instead, contact the nearest service center!
Jan 09, 2015 | Canon IR 2200 Digital Copier RECONDITIONED
Erroe code 000000-0000
cannon iR2200-3300
error code 000000-0000
how to solve the proble
Feb 21, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
ImageRUNNER 3300 All-In-One Laser Printer: PLEASE TELL ME SOLUTION FOR THE ERROR CODE OF IR22...
* 2 8 * ( service mode )
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on
If does not helps replace fixing film assy
May 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I want to scan a paper using the cannon ir2200 super g3
Do you mean scan to your computer?
If so first you need to make sure it's networked. When you press the counter check button do you see IR2200(IR2200N)? Also is there an ethernet NIC in your copier?
If your copier is not networked you will need to get a tech to come and install a NIC and load the necessary firmware.
Then if not already setup on your network:
Do you have the Network Guide?
Go to page 2-11 and follow the instructions there.
You can click the DHCP icon and hopefully you'll get an IP address etc. (you may have to restart using switch on right hand side of copier to turn off, wait a while then turn back on). Once you have an IP address click on the DHCP icon again to make sure it's not filled in with black and save settings.
IP address must be in same range as other devices on your network e.g 192.168.1.x or 192.168.0.x (only specify a number for x between 1 and 254, must not be used by another device). Subnet mask must be same as for other devices. It's probably 255.255.255.0 Once setup on your network, download Canon Network ScanGear 2.21 (don't get the colour version) and follow the instructions in the manual included with the download.
Dec 17, 2009 | Cannon i70 Printer
Error message on cannon super g3 copier E602-0001
Ok pls. tell exact model "superG3" is fax speed.eg. IR2200,np7161,...
Sep 23, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon iR2200
press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
Jul 14, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Error code E000740-0003
hi the error code means tah lan card cannot be read and faulty check the harnes betwen it and the PCB if its ok change the card thanks.
May 20, 2008 | Canon imageRUNNER 2200
23 people viewed this question
k24674
