Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Mower will start but runs rough & stops
Strong smell of gas when mower stops. I have installed new spark plug & air filter.
    Champion:
  • 225 Answers
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Posted on Apr 25, 2014
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: lawn mower runs rough.got fresh gas,new spark
Hi fcruz775
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 19, 2011
Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Nov 25, 2011 | Mtd 22" Yard Machine Push Mower
Have gts toro, engine starts then stops can not get it started.. r s
Your mower engine has to have these things WORKING to run: 1. Compression (engine in good shape) 2. Strong Spark (magneto air gap has to be correct for strong spark) 3. Clean air ( good, clean air filter w/no air leaks) 4. Clean, fresh fuel supply (gas less than 30 days olds with an inline filter installed in mower's fuel line). These things are assuming the mower hasn't struck an immovable object such as concrete, tree stump etc. recently. This will shear the flywheel key and timing may be off so far that engine won't start. So, where would you like to start my friend? Try checking these things. In the meanwhile....we can try to "coax" the engine into running. Remove the spark plug. Get an aerosol can of carb/choke cleaner spray. Spray a couple of shots into the engine. Reinstall plug. Choke the carb and attempt to start. This may or may not work, according to the conditions listed earlier. If this doesn't get it running, remove the plug and try it again.
We are trying to get it to run on its own, so it will start (or attempt to start) drawing fuel from the carburetor. Sometimes the brass bolt that holds the carburetor float bowl on gets clogged. You drain the gas, remove the bolt and clean all the small hole in the bottom and along the sides of it. This bolt is also the main jet of the carb. Cleaning this with carb cleaner can only help. If you do this, use NO metal objects to poke or scrape the bolt. The holes are metered and have to stay that way. Check for spark, check your air filter, see if the plug gets wet after you attempt to start. If it doesn't get wet or even smell like gas, then likely you have a fuel flow problem. Try ALL these things and post back; and again, if you have hit something solid recently with the mower, you will have the replace the flywheel shear key. It is a small aluminum $1.00 part so don't worry. Post back as needed. We wish to help.
Jun 19, 2011 | Toro Lawn Mower With Toro Power Tools
New plug will not turn over prime and still will not turn over or run
Jun 19, 2011 | Toro Power Lawn Mower
Murray push mower 22" Model 223311X8A Briggs & Stratton motor idles slowly, coughs & spits, stops in middle of lawn and won't restart. Had tuned up, then brought back for recheck. Still...
There are several additives on the market for gasoline, but only a few of them actually help anything. If the additive is relatively cheap to buy, don't expect much results. Gas that hasn't been treated with fuel stabilizer that is a month or more old loses its volatility and can cause issues with engine performance, small and large.
All you guys on the block need to make sure you're using fresh gas, Clean SAE 30 Weight Oil for the Briggs Engines and good clean air filters. Also you can tell when gas is going stale..it starts smelling kind of like turpentine....a smell you'll never forget.
Jul 11, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
Briggs & stratton 4hp push mower
why dose my motor cycle up & down in rpms
Jun 01, 2009 | Mtd 22" Yard Machine Push Mower
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Yard-Man Mower model 418D401 doesn't start
Need to remove carberator bowl nut and bowl and activate float to smell new gas coming thru,stuck mostlikey due to storage.
Please rate. Thanks. jj505
Mar 29, 2009 | Garden
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
241 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
