Samsung ht e5500
Will not play most dvds. The dvds are clean, scratch free. Loads and then states cannot read disc. Cheap $5 dvds play but all my regular dvds will not
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Posted on Nov 26, 2008
  • 11 Answers
SOURCE: LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
Posted on Sep 19, 2009
hawk127311
  • 350 Answers
SOURCE: i cant play any discs on my samsung ht x200 due to
Go through the set up menu on the Ht DVD player (if it's all in one) and change your settings for the region code. Obviously it is not the one that you have already set it to (probably set by manufacturer). NTSC, PAL, etc. I hope this helps.
Posted on Oct 26, 2009
SOURCE: Samsung HT-Z310 tries to load disc, but never does
I've had a similar problem where the disc continues spinning in the "loading" mode and then finally goes to "disc error." So, I opened the cover of the player, and noticed that the disc was not spinning as fast as I expected, and there was an extra unpleasant sound when the disc was spinning. Thus, I suspected there was an issue in the drive motor system: either the motor drive board, the motor itself, or the contact to the disc. I saw that there was dust accumulated on the rubber contacts to the disc, so I cleaned them with a q-tip. I then resetted the system, and the disc was the spinning normally again, and everything worked like before! (Other things I have tried in the past were cleaning the lens and updating the firmware, none of which worked) I hope this helps!
Posted on Nov 23, 2009
  • 10 Answers
SOURCE: 3 year old samsung audio/video 5 disc player keeps
your a ********, the cd player is rooted
Posted on Jan 07, 2010
Everytime i put a disc in it says no disk who do i fix it to play my movies?
If you are lucky all that has happened is that the lens that reads the disc has got dust on it and needs cleaning. You can get a lens cleaning disc or other DVD lens cleaning products from a shop for this. If you are unlucky then a bit of dirt has scratched the lens and it will need replacing.
Dec 05, 2015 | Samsung HT-X40 System
Samsung home cinema ht-330 dvds wont play no disc displayed
The most common reason is either a dirty or bad Optical Pickup unit in the player which is what reads the disc, and you will get no disc, cannot read disc etc.
Dec 20, 2012 | Samsung Audio Players & Recorders
How do i change my region on my samsung HT-E3500 i am in mexico and can't view my dvds from the states
tengo la misma pregunta , lo he comprado en el palacio de hierro y no pudieron hacerlo multiregion , lo llevare a un centro de atencion a clientes , si se algo te paso el codigo o, o si tu lo sabes antes me lo pasas . Saludos
Nov 10, 2012 | Samsung HT-E3500 3D Blu-Ray Home Theater...
My samsung ht-p10 home theater system displays "No Disc"
..I would assume that you have carefully cleaned the lense and inspected the flexible ribbon cable..try replacing the spindle motor..in our case they are not expensive..good luck Elben
Aug 24, 2012 | Samsung HT-P10 Theater System
Hi, My Home Cinema Samsung HT-TXQ120 seems not playing double-layer DVDs. The 4GB DVD are played perfectly, while when I try to play 8GB DVDs, the image gets frozen very soon (less than 1 min) and never...
Hi. There is a change in focus by the laser for a dual layer DVD - the laseer has to read through a semi-transmissive layer for that extra information too.
Cleaning your laser lens with a cleaning disc kit may bring it bck to life especially if you smoke... else could be time for a new laser(s)
https://www.bandcds.co.uk/faqs/dual-layer-dvds
Jan 19, 2018 | Samsung HT-TXQ120 Home Theater System...
SAMSUNG HT-P10 DIGITAL HOME THEATER SYSTEM wont play DVDs
You could try cleaning the drive with a dvd cleaner disk and also a can of compressed air to blow into the drawer. It may just be dirty. Good luck! I hope this helps you.
Aug 27, 2009 | Samsung HT-P10 Theater System
Samsung HT-P38 won't play DVDs but plays CDs just fine
I called Samsung. They told me how to do a software reset and solve the problem
1. Take out all CDS.
2. Turn off and then on.
3. HOld down stop for 5 - seconds.
Problem Solved!
Apr 11, 2007 | Samsung HT-P38 System
Dvd does not load
clean the lens of your dvd if that does not work there is a strip connected to the lens have that replace or adjusted by a tech.good luck.
Apr 03, 2007 | Samsung HT-DS1000 System
160 people viewed this question
 Grubhead
Grubhead
