Question about Olympia Compact S & User Manual Typewriter W/ Warranty
Olympia typewriter carriage not moving and keys not working
Pulled this typewriter out of storage and turned it on. Powers on and lights light up... it worked for a millisecond, but then the carriage stopped moving and the keys don't respond when pushed. Anyway I can fix this?
3 Suggested Answers
  • 23 Answers
SOURCE: I can't unlock the carriage on my old Olympia typewriter
YEP, MOVE THE PAPER FEED SELECTOR TO NUMBER 1
Posted on Sep 17, 2010
  • 3594 Answers
SOURCE: Olympia Startype electric typewriter , make a
Turn it off and see if the carrier will move back and forth by hand if it will but feels a little gummy spray a little WD40 on the silver shafts that it slides on. If it won't move by hand look for debris in the carrier area.
DickyO
Posted on Sep 19, 2011
How do I increase the area where I can type?
Press margin release key, move carriage using backspace to where you want the left margin to be and press left margin set key. Repeat for the right margin, use space bar to advance the carriage and press the right margin set key instead.
Sep 10, 2014 | Olympia Startype 3 Typewriter
Carriage return stuck on left side when powering on
The first thing to try is to lubricate the silver rail that the carriage rides on. A few drops of a light oil ( sewing machine oil ) may take care of the problem. Turn machine off, apply oil and move carriage by hand back and forth. Turn back on and see if this took care of it.
May 14, 2013 | IBM Wheelwriter 6 Typewriter
I have an Olympia Progress manual typewriter. It seems to be in good working order, well oiled and good action in the keys, except the carriage won't advance when I type. I don't believe the...
try typing with a little pressure on the carriage (push with right hand to the left) if it work like that then the carriage pull cord may be broken
Apr 23, 2013 | Office Equipment & Supplies
My old manual Olympia typewriter always stops in the middle of the carriage when typing. If I hit the shift key it will move forward and I can continue to type. What is the mechanism that makes it s
The carriage is touching the cavers it need the flat rubber washers that are between the case and the frame look at the bottom of the typewriter remove the screw slip in a new washer and replace the screw do the same on the other side
May 21, 2012 | Olympia Manual Typewriter
Olympia Startype electric typewriter , make a funny noise and won't move carriage. Can not get it to work.
DickyO
Sep 19, 2011 | Olympia Office Equipment & Supplies
Typewriter problem
IF THE CARRIAGE IS NOT MOVING LEFT OR RIGHT, CAN YOU PUSH THE CARRIAGE TO THE RIGHT OR LEFT??? OR IS IT COMPLETELY STUCK. YOU CAN TRY CLEANING THE SILVER SHAFT THE CARRIAGE SLIDES ON AND LUBRICATING THE SHAFT WITH A LIGHTWEIGHT OIL, WHEN YOU PRESS THE KEYS DO THEY WORK.???
Mar 18, 2010 | Olympia Mastertype 3 Typewriter
Printer just beeps and carriage wont move.
No...you may have broken wire or wires in the cable harness that runs from the carriage unit down to the PCB. The cable/carriage will have to be relaced if they are broken.
Aug 06, 2009 | Olympia Mastertype 3 Typewriter
Carriage remains stationary when typing. Is there a way to unlock
Mant portables have a lock to hold the carriage in place while in the case, on the rt. or left sides below the carriage.
Hope this helps
DickyO
Apr 14, 2009 | Olympia Office Equipment & Supplies
No Typing, but Powers Up, brother ax-25
open your typewriter and muve prinre left-rigt, you have a prnters jam or power suply module is not ok too low dc voltage
Jan 25, 2008 | Office Equipment & Supplies
Olympia Compact S & User Manual Typewriter W/ Warranty Logo
55 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
