Question about Garden
Lt 166 govenor adjustments how to
How to adjust the govenor
    Novelist:
  • 212 Answers
Your governor should not need adjusting unless someone moved it and you want to go back to factory setting. Having said that. You will loosen small nut on bottom of governor, follow the travel of governor to watch the throttle in wide open position. Hold it in that position then with needle nose grip the center of stud coming out of bottom center of governor and move this all the way in same direction as wide open throttle, then snug it up and your done. Good luck.
Posted on Jul 22, 2013
2 Suggested Answers
  • 19 Answers
SOURCE: adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Posted on Jul 19, 2010
When trying to generate electricity, it stalls. Oil level good and carb has been cleaned thoroughly. Linkage for auto throttle up is moving like designed. Any thoughts?
will assume it a petrol not a diesel
that govenor is adjustable
with all the load and vibration and use
sometimes that govenor adjustment will need a twig
lever moving up and down is a good sign
does it need a spark plug
or valve adjustment
if all that is ok
if you push that lever slowly full forward and motor stalls
may tell you its govenor needs a twig
Oct 08, 2016 | Electrical Supplies
My Honda gx340 is revving high all the time Can some one tell me y thank you
should be an internal govenor on a plant unit like that
there is a thicker than normal metal rod running off the carby to the motor and that is where you adjust the govenor
cant find good instruction how that governor is adjusted ..if adjusted the wrong way it will rev out may even throw a piston
then check carby idle adjustment
should hunt (rev up and down only slightly )as load changes
you tube
11hp Honda GX340 cold start
https://www.youtube.com/watch?v=i3_v68__X5o
Honda GX340 HGI Partsf21c43c2-def4-46c5-9224-ed46701c0c01.jpghonda-gx340-revving-high-all-time-some-qkhmqzcwln4tohiil4ndbnz4-2-2.jpg
Jun 22, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Model LT 166. Why won't it start?
Most are in pos. cable in or below battery cable. When was the valves adjusted? If out adjusted the compression may not release
Jan 09, 2016 | John Deere Garden
ADJUST THE GOVENOR ON MY LT 155 John Deere lawn tractor
This should be Kawasaki engine; although, it could a Kohler. The IPL on this doesn't specify which engine it has. It would nice if it did where I could look the engine's service manual but the following should be what you need.
You place throttle in full throttle position. You need to watch the linkage at the governor shaft for which it turns as you go to full throttle then you would continue turning the governor shaft in that direction until it stops. From there you tighten the retaining bolt or nut and you should be good to go.
Nov 08, 2014 | John Deere Garden
My lt 1000 mower nearly dies when going into taller grass, I have to raise the deck to the highest position. I just replaced both blades
thats normal but if you want it could be a govenor has come out of adjustment take it in to check it should cost 30.00
Sep 02, 2014 | Garden
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
How honda gcv 190 rpm adjust
you need govnor adjusted take to shop govenors are tricky
Jul 27, 2014 | Honda Garden
Our cs56 pro will idle all day but it won't rev up
That CS-56 soil compactor is set up with a govenor to stay at a fixed speed! If you need to change the speed you need to reset the govenor bu adjusting it to tighten the spring. If the revs increase in that direction OK, otherwise turn the adjustment the other way!
Jan 01, 2013 | Cars & Trucks
I want to adjust my 1500watts generator,how will i do it?
What do you want to adjust? The voltage is likely NOT user adjustable. The frequency is controlled by the speed govenor and needs to be checked under load. For engine adjustments search google for small engine repair for tips.
Mar 22, 2010 | Electrical Supplies
John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Jun 14, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
169 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
