Question about Daewoo 719B 17" CRT Monitor
Lack of enough brightness
My monitor starts up properly but the brightness is too low and there is no red,green and blue drive to adjust my brightness.how do i go about it.DEL
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
It may be a blown backlight. if the image is very very faint, then the backlight has most likely blown. lcdpart.com can get you a new backight, but the replacement will have to be done through a local repair shop.
Posted on Aug 29, 2007
SOURCE:
The color on my tv is turning green. It's not totally green but it's becoming green. No matter how I adjust the colors it remains the same with too much green. You can't see the true colors...
It is very common for the color of the lamp to change as it nears the end of it's life. Depending on the bulb itself you may see yellow, green, or blue shifts (I have even seen red/orange). This is due to the diminishing output of the bulb and while you can make some adjustment you will eventually hit the point of failure. The bulb could in fact last several more weeks or even months depending on your use and environment. It is probably a good time to start searching for a replacement now so you can replace it as soon as it dies or just replace it now if the color is too bad to be worthwhile.
May 23, 2011 | Philips Magnavox 9P6034C 60" Rear...
My monitor stays white it wont show any display
black-icon.gif This icon indicates the BRIGHTNESS control, more properly called BLACK LEVEL. It adds or subtracts an offset, or bias, into the red, green, and blue signals. This control should be adjusted so that black picture content displays as true black on your monitor. Misadjustment of this control is the most common problem of poor quality picture reproduction on computer monitors, video monitors, and television sets. Later in this document, I will explain how to set this control properly. The setting is somewhat dependent upon ambient light. Modern display equipment is sufficiently stable that frequent adjustment is unnecessary.
picture-icon.gif This icon indicates the CONTRAST control, preferably called PICTURE. It applies a scale factor (gain) to the red, green, and blue signals. It affects the luminance (proportional to intensity) that is reproduced for a full white input signal. Once BRIGHTNESS is set correctly, CONTRAST should be set for comfortable viewing brightness.
The gamma can be controlled through Video Card utility which can usually be accessed by going to display properties.
Depending on your video card software you may be able to right click your desktop, select properties, select settings tab and then choose advanced, towards the bottom. In there you may find a tab called Monitor and under that tab you may or may not (depending on your video card software) be able to adjust your color correction settings(gamma & brightness & contrast).
. Right click on the desktop and then select Properties
2. Click on the Settings tab and then click on the Advanced button.
3. Click on the Color Correction tab and you will see settings for Brightness, Contrast, and Gamma
Jan 29, 2010 | Computers & Internet
Color output to screen lacking red
You have ruled out the graphics chip by plugging an external monitor in, the chips fine.
Now you have to look at the inverter. Sometimes a cable will work itself loose from the inverter, causing the display to go wild and show strange colours where is should be white.
What you have to do is remove the screen bezel (the plastic screen surround) this reveal the screen, look at the bottom of the screen for a thin circuit board with cables coming from it and make sure the cables a plugged in properly.
If you need anymore help or advice please post back.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Dec 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
CRT-Monitor
my e70fsb monitor is self adjusting, brightness goes to maximum
Aug 05, 2008 | Computers & Internet
Open Questions:
See all Daewoo 719B 17" CRT Monitor Questions
Daewoo 719B 17" CRT Monitor Logo
Top Daewoo Computers & Internet Experts
Ekse
Paul Bade
JonSnell Electronic
JonSnell Electronic
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
