Question about Olympus FE-180 Digital Camera
Unable to take pictures
When I turn on the the camera the LED between the "red" camera button and the "green" playback remains red. I am unable to take a picture. When I press these buttons nothing happens. There is power going to the camera and I can view thru the LCD.
    Genius:
  • 2,985 Answers
This is a main board failure - check Olympus Web site there may be a repair or you may consider junking it and starting over.
Posted on Aug 29, 2007
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
My digital camera FinePix A900, keeps turning off when I turn it on. Unable to pull any menus. Batteries are good. any suggestions, is it fixable or do I have to buy a new one?
Try pressing the playback button to turn the camera on. This should turn the camera on just so that you can view any pictures stored on the card or internal memory. You can also access the menu functions this way. Also try pressing the picture/shutter button and see if the lens extends. If the camera shuts off when you press the picture button and the lens does not move or only moves a fraction then the problem is probably to do with the lens
Dec 18, 2009 | Fuji FinePix A900 Digital Camera
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Picture lock
Protected pictures cannot be erased using [ERASE],
[SEL. IMAGE] or [ALL ERASE], but they are all erased by
formatting.
• Go to Playback mode in the camera. Select the picture to be unlocked with the left or right arrow buttons, and to remove the protection select OFF with the up or down arrow button.
Dec 19, 2008 | Olympus FE-220 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Nikon coolpix2100 not turning on
what does the manual say about the Green LED? Take a look through this list http://www.fixya.com/support/p438-nikon_coolpix_2100_digital_camera/solutions
May 20, 2007 | Nikon Coolpix 2100 Digital Camera
Redeye
Red-eye is actually caused by the light from the flash bouncing off the back of the retina and picking up the color red from the blood vessels. To correct this effect, follow these steps: Turn the mode dial to PlayBack Mode (green arrow) and display the image with redeye. Press OK\Menu button. Using the arrow pad, navigate to MODE MENU>EDIT>REDEYE FIX. Press the right arrow key, START will display. Press OK\Menu After {BUSY} bar displays, a screen will display with an option to cancel or save the image. ? If the option [Go] is displayed, press the OK\Menu button. This saves a corrected version of the image. ? If the option CANCEL is displayed, than the camera was unable to correct the image. Press the left arrow key to exit. This correction may not work on all pictures. If you import the original image into Olympus Master software you can also apply the Red-Eye fix located in the Edit menu. This lets you precisely pinpoint the eye area and remove the red. It even lets you remove green or blue, which can occur with animals.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Redeye
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Olympus FE-180 Digital Camera Logo
46 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
