Question about Cell Phones
Clarion cx501 to iPad via bluetooth under "pairing" audio is not as an option
renosean
  • 492 Answers
SOURCE: z3 bluetooth problems
You must be activly paired to another device for that option.
Posted on Mar 07, 2008
Bajanguru
  • 7752 Answers
SOURCE: problems pairing with PC via Bluetooth
Guest - let's remember that wireless is not bluetooth on a computer if your computer does not have bluetooth then you need to buy a bluetooth adapter.
batin73 - I really can not say why that is happening with you pairing the system to the phone.....i will check on that and get back to you.
Posted on Mar 28, 2008
Dipu007
  • 2110 Answers
SOURCE: No Send Via Bluetooth optionon SCP-6650
First select the file and press option >send>via bluetooth
Posted on Dec 09, 2008
  • 10 Answers
SOURCE: Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Posted on Jan 28, 2009
SOURCE: Problem connecting headset via bluetooth on PC
You have to press the button to turn it on and hold the button pressed until it flashes red. Then you go in the control panel , bluetooth options, click it , and then go in the find devices options. When the computer finds the device you have to use the option to put your documentation key and use this default number 0000.
Conclude your installation.
Posted on Aug 01, 2009
Need wiring diagram for clarion cx501 double din car stereo Thank you
Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Apr 05, 2015 | Clarion Car Audio & Video
Pair to iPad
Till now I did not know you could pair a mouse to an iPad. When someone is selling mice you can connect via bluetooth, they will give you the manual to. I hope you know, the iPad is not a computer on which you can connect lots of things. Only when Apple allows you to put anything on, or connect via bluetooth, it can work. Not when you think it should be great.
Because Apple made it possible to connect their key board to the iPad, you now can buy third party keyboards that work with the iPad.
Jan 30, 2015 | Ckeyin Mini Optical Bluetooth 3.0 Wireless...
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
Clarion bluetooth does not recognize my phone after someone else drives my car.
Sounds like you need professional assistance. Recommend contacting a local car audio professional or Clarion customer support directly here:
Apr 08, 2017 | Clarion Car Audio & Video
My refurbished Clarion cx501 is blowing the fuse in my 2005 Chevy Colorado.
I f you are using the plug and play harness that comes with you truck. Then go throw and just the radio its own power with its own fuse and then ground it to the body of the truck and see if that helps. If it does not help then take the radio out hook it to the battery with a fuse in line and see if it still blows the fuse, if it does then there is something in the radio that is not right.
Dec 02, 2013 | Clarion CX501 CD/MP3 Player with usb Aux...
I have a Clarion THD301 connected to a CX501 receiver. It does not work as advertised. Anyone have any solutions to this?
Not as advertised eh? Are you sure about that?
Jan 11, 2018 | Clarion HD Radio Tuner THD301
Bluetooth audio streaming breaks up on Clarion CX501
This is not a solution but my Nokia Lumia 920 does the same thing. There are several post on the internet all pointing back to the 920 and iphone 4. I think the only link here is the cx-501. Clarion support is playing the blame game and blaming my 920 as the problem.
Mar 18, 2012 | Clarion VZ400 Car Video Player
Old phone would pair with Clarion VRX785BT's bluetooth
you auto connect is turning off on the screen. try keeping ur phone permantley visable.
Jan 10, 2009 | Clarion VRX785BT Car DVD Player
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
