I have a HP4455. It has a Quantum Fireball 3.5 HD. A few weeks ago i turned on the computer and nothing. Says Operating system not found. I went into BIOS. Listed none for Master and Slave I went into user and put in the numbers for the CHS, but it still won't boot up. Also installed new battery. Any ideas? Or is it dead??? thanks
Windows 98 computer, huh? http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph04973&lc=en&dlc=en&cc=us&lang=en&product=58161 Suggest you try a different, known to be good, flat ribbon interface cable. Sometimes these interface cables go bad.
Harddrives are a mechanical device. They have a 'Life Cycle'. After so many hours of usage, the life cycle come to an end. Kind of like for a human being. It could be your harddrive is at it's end.
You could try installing this harddrive into an inexpensive external enclosure.(Uses a USB cable) Plug it into a working computer. Go to My Computer, find which drive letter it is, (Example: (D:) or (E:) or (F:), double-click on that drive letter, and see if you can access this harddrive. Your harddrive is an IDE harddrive. IDE is also referred to as EIDE, ATA, and PATA. It is a 3.5" harddrive. Examples of inexpensive IDE external enclosures, http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2779&name=3.5-Enclosure-IDE&Nav=|c:2778|&Sort=0&Recs=10
Was this helpful?
Yes
No
Popular Solutions for Quantum 13Gb FIREBALL CX 3.5"
Hi. I am trying to upgrade from Windows 98 to 2000. Sadly, Windows 2000 will not recognise the hard...
(More)
Hi. I am trying to upgrade from Windows 98 to 2000. Sadly, Windows 2000 will not recognise the hard drive driver. The hard drive I have is a Quantum Fireball CX 3.5 series (part # CX10A001 Rev. 02-B). Where can I find a driver compatable with Windows 2000? I've already tried contacting the manufacture(s) to no avail. Can anone help me with this issue? Thanks very much.
I am setting up a new pc with a primary hard drive on a SATA cable. I would also like to use...
(More)
I am setting up a new pc with a primary hard drive on a SATA cable. I would also like to use the hard drive from my old PC which is a Quantum CX 3.5 and an IDE cable. Do I need to set the jumpers on one or both drives if they are not on the same ribbon?
hi! i have a quantum fireball scsi drive and i try to load windows nt 4.0 on it. i start the setup...
(More)
hi! i have a quantum fireball scsi drive and i try to load windows nt 4.0 on it. i start the setup with the 3 setup diskettes using the floppy drive. during the setup i locate my drive controler and then it ask for any other support for mass storage devices. i skip that step coz i donot have the driver for the drive but when it comes to load the operating system ,it does not read the drive and the message "drive is not accessible" is displayed. where can i get the driver from? or is it the termination ? please help. thanx rocky
