Question about Dishwashers
Kitchenaid Model KUDS301XWH4 won't start after pushing normal cycle and start. Lights blink and beeps eventually stops. child lock is not the issue
Lights blink and beeps begin, but the dishwasher won't start. It is not the child lock, I have already checked that.
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Posted on Feb 09, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
  • 3 Answers
SOURCE: My normal cycle and cancel button lights are
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Posted on Apr 27, 2009
SOURCE: electrolux dishwasher all lights blinking and wont
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
Posted on Dec 12, 2009
Blinking child lock light
Under the child lock icon, push and hold the button until it beeps, this should unlock your panel. Good Luck
Apr 13, 2016 | KitchenAid Dishwashers
The child lock light flash
Hello. Your Kitchenaid unit has the child-lock enabled. Look for a button(or set of buttons) that has a small lock symbol beneath or the word "lock". On most models, you have to push and hold the button(s) until the lock light goes out(usually about 3-5 seconds). That should disable the lock and the unit should operate normally. I hope this helps you!
Dec 18, 2015 | KitchenAid Dishwashers
Start button blinks
It sounds like you have the child-lock or control-lock function turned on. To turn it off, just press and hold the Heat (or Heated Dry) button for 4 or 5 seconds. That should unlock you dishwasehr and you can now use it normally.
Aug 05, 2014 | Kenmore Dishwashers
My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
Oct 22, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
KUDI02IRBS Kitchenaid dishwasher won't start cycle
Perhaps the child lock is on. Push and hold the heat/dry button for 5 seconds and hopefully the keypad will be unlocked. Hopefully that will work for you.
Mar 19, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Start up Fault
there should be a trouble shooter in the console the blinking lights will tell you what the problem is and the common issues are listed on that paper.
Nov 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 | Dishwashers
Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Feb 12, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
81 people viewed this question
Top Dishwashers Experts
Owen Barnes
